After changing the lower drive belt, and reassembling and testing. The tractor did respond to forward and reverse, however, there seem to be a loud noise coming from somewhere underneath. I think toward the front. In addition, After putting in gear and moving, it would tend to slow to a crawl(loose speed)What did I do?
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
SOURCE: John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
