Question about Abit AN9 32X Motherboard
Sound like siren coming from cpu . Plz help - Abit AN9 32X Motherboard
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
If it is a constant sound then it most likely is the fan. As they wear out they can get noisy. Start there first. You may be able to unplug it and then start up to see if it quits. Just make sure that after it starts up and you log in, shut down the system and reconnect it. If that is not it the only other thing I can think of is an alarm, but those are usually only seen on servers....
Posted on Jun 16, 2009
Siren sounds on the computer
how much beep?
a siren could be:
- overheat
- RAM dead
- CPU dead
- PSU dead
- motherboard dead
a siren and nothing else is a critical error
Nov 22, 2012 | ASUS P5LD2-VM Motherboard
Sometime a sound come from my computer?
If the sound is happening right at power on, then it's coming from the motherboard's POST testing. Considering it stops, the most likely cause is a fan that is starting slower than normal (wearing out), and is falling below the speed threshold set in the BIOS configuration.
Oct 28, 2009 | Computers & Internet
Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
Jul 30, 2009 | Computers & Internet
When i scan mycomputer then it keep siren continuously
The sound you are hearing is a warning that the CPU is over heating.
Try cleaning the CPU fan & the heatsink the fan is connected too.
If you built the system did you add thermal grease between the heatsink & CPU?
It is also possible the thermal grease has dried up & is no longer allowing the heat from the CPU to transfer to the heatsink. It may be time to replace the heatsink assembly.
If your over clocking the CPU reset it to normal.
Luck!
Mike
Jun 02, 2009 | Abit IC7-G Motherboard
Alarm siren sounds every 5 seconds.
sounds like a defective door ajar switch or a defective seat belt switch.
Mar 27, 2009 | 2000 Renault 181
I have no sound coming from my AU-93 car alarm
probably the siren is damaged hook up another one or try with a tester light on the wires from the siren when the alarm is on and the lights start to flash the light on the tester light will stay on.if this happen then your siren is damaged.or email me for more help, reynosaelectronics@live.com.mx
Mar 16, 2009 | Vehicle Parts & Accessories
Two tone Siren from MoBo/over heating CPU
at first go to the bios. then default the bios setting. then check the system monitor. if the cpu is too hot you can see it. or you can change the processor. never over clock the processor.
Jan 20, 2009 | Abit AI7 Motherboard
Computer shuts down
check temperature of your pc, if it goes then use proper system fan and also clean your system from dusting.
Oct 17, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
ABIT-BL7 make sound
For reference, specifically, this would be indicative of an alarm on the motherboard. The only typical alarm of this nature would be an overtemperature alarm, either for chassis or (more typically) CPU temperature. In this case, it sounds like the CPU fan was failing, causing the CPU to overheat; once the threshhold temperature was reached (BIOS configurable), the alarm sounded. Remember, boys and girls, if your computer is making a sound like an ambulance, there's probably something bad going on.
Aug 15, 2007 | Abit BL7-RAID Motherboard
Open Questions:
The Best Cheep Cloud Storage and Backup Services ' DataAlign You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Cloud Backup For Small Business services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Server Cloud Backup Solution Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Backup Pricing Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Aug 21, 2018 | Best Computers & Internet
See all Abit AN9 32X Motherboard Questions
Abit AN9 32X Motherboard Logo
94 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
