Question about GE Profile JT912 Electric Single Oven
Missing manuel Code showing - F 2 -
Yesterday water spilled over from pot onto burner, then code showed on display panel - F 2 - now nothing works.  What could be going on?
  • 4 more comments
  • Amy Campbell Nov 10, 2007
    Same Problem as V Russell.
    Soup boiled over, spilled on range, now receiving EO F2 error code and oven not working.
    Any and all help or advice is appreciated
  • Anonymous Dec 07, 2007
    Fan remains on long after cleaning cycle. Cannot turn off . F2 code
  • Anonymous Dec 20, 2007
    water was spilled on front of oven - now we get the F2 errr nothing works.
  • munmus May 08, 2008
    after my maids left the display panel has been showing EO F2 .dont know whats going on
  • daddyto2 Sep 12, 2008
    Water was spilled down the front portion of the oven and the F2 error code is flashing. It did this a few months ago and after a day or so of, I'm guessing, just drying out it began working again. I hope that in a few days it starts to work again. My guess is that the controls are not waterproof or resistant to the moisture and water that was spilled on the stove top.
  • chrisdmom2 Dec 19, 2008
    My oven just started displaying code EO F2 for no reason! I came home from work and it beeped and there was this code! Nothing about it in the manual! Anyone figure out what this is?? Oven does not work at all!!
  • 3,230 Answers
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Posted on May 26, 2009
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Kenmore electric built-in oven model 911.47702201 just started showing 2 error codes and beeping. F7 is in red and on the left side of the display, E8 is in green and flashing and is on the right side of...
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. Good luck!!!
Nov 04, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
The lower over is not working.It has displayed a "code" that looks like a half of a "H". The upper burners work
Which half of the "H" is missing upper, lower, left, or right ? Do you want to attempt the repair yourself ? If not, then it does not matter what the code means-----you still need to call an expert. You can try something on your own: unplug the electric cord, wait 2 minutes and replug. This sometimes resets the electronics and the code fault will then disappear and possibly the oven will work. If the code still shows, or the oven will not work , you need the expert. Good luck, Macgivor
Oct 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
Whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
May 08, 2008 | Ovens
Troubleshooting
need the Model Number first to see what the codes mean
Mar 31, 2008 | Ovens
790.7921
Does the bottom ignito glow when the "bake" option is selected? If not, replace the ignitor. Even if it glows, it may not be achieving the electrical resistance value needed by the safety valve to open thus allowing the gas to flow to the burner.
Aug 23, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
GE Profile JT912 Electric Single Oven Logo
178 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
