Question about Philips Televison & Video
Philips 60 inch tv won't turn on, L.E.D.s flash and chirp sound
I have a Philips Magnavox Model #7P6033 60 inch projection TV with chassis #PTV775-AH01 that was working perfectely until it just shut off. When the power button is pressed the green and red L.E.Ds come on momentarly then go out. A small chirp can be heard from the back of TV. But there is no picture or sound. I believe power supply is shuting down. I'm no TV repair man but can identify parts some what, and can replace parts if someone can tell me where to get them.
Thank You!
  • 1153 Answers
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Posted on Aug 25, 2007
ctf1800
  • 4402 Answers
SOURCE: 60" Philips Magnavox Projection TV Red Screen
You can also check to see if you have bad fluid problems, by looking down in your crt's with a flashlight when you unplug your set and see if you can notice any particles that should not be there. Look at all three and see if there is a difference. It should be clear, if not then you need to change fluid and clean.
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Posted on Dec 17, 2007
  • 2336 Answers
SOURCE: MAGNAVOX 50 INCH REAR PROJECTION Hor. Output Tran Keep Going Out
Try checking some of the tunning and coupling capacitors around the horizontal section as well for some crystalized solder joints in that area.
Posted on Jan 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Posted on Jan 25, 2008
I bought a crappy old magnavox and rebuilt it. I had both of these issues.
Since your tv is old, the blur problem is probably caused by old coolant in one or more of the CRT lens couplers. Hopefully, the lenses are simply out of alignment, but no one has ever worked on the tv, then this is unlikely.
First, unscrew the back panel of the tv console (should be a bunch of 1/4" hex head screws). There will then be a large white panel at a 45 degree angle held in place by two tabs or maybe even screws. Remove it to see the CRTs. A quick check for the blurry problem is to look directly into the CRTs while the tv is off. DO NOT do it while they are on if you can help it, as it is not good for your eyes.
Shine a white LED flashlight down into each of the CRT's top lenses. Avoid classic incandescent light in this case, since you will be looking for the difference between white and yellow. I you see a white plate inside, good. If the inside looks yellow, and has floating things in it, then the coolant fluid inside is old and bad. You can replace this, but it is a VERY delicate task and MUST be done in certain steps to avoid ruining the electronic boards anywhere within splash zone or drip reach of the lens couplers. The coolant is a special blend available at most tv repair shops, but it's basically clear antifreeze (which you wont likely find in an automotive store).
For the color being off, it is most likely the gain on each CRT being out of whack. First, change all of the user settings (in the on screen menu) for image, color, sharpness, etc to the middle or default.
With the back panel off, somewhere near the bottom of the inside there will be a small black plastic box with wires coming out the sides. This box should have 6 knobs on the front of it (the face facing the rear of the tv); 2 rows of red, green, and blue knobs. These are the screen controls for FOCUS and GAIN. And they should already have some sort of label telling you so.
I placed a mirror in front of my tv so I could see the screen as I adjusted, but you might be able to see it somewhat by hanging a sheet over the front of the screen and looking at it from the inside.
There's a much more in depth method to do this that is described in the service manual (which you are likely to have seen by now; they are usually either stapled to the back of the tv or hanging somewhere inside and easy to see)
But basically, just turn the knobs gently around until the picture looks about right to you. (Remember, if you turn them all up super bright, the CRT will not last very long. Try to keep the knobs near the middle of their turn ability)
If you want to do a full out overhaul of the screen, you'll have to make a lot of adjustments with a bunch of little knobs (variable resistors, really) on the computer board inside. The service manual will tell you what each one corresponds to, but most of them will have a subtle label on the board.
Email me if you need any help
Posted on Mar 23, 2008
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
be able to help more if you post model# and chassis.........meder's tv
May 19, 2009 | Philips Televison & Video
My 60 inch magnavox tv has no picture or sound when turned on
Do you hear a chirping sound? If so goto www.TvRepairKits.com to get their chirping set repair kit.
Apr 05, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Contact us at www.TvRepairKits.com. We are working on solving this problem as we speak.
Nov 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Same problem as JoshJOhnson posted on Jan 21 08
What is the chassis number on that set. We have a complete Chassis that we are parting out HDTV magnavox with the DPTV 305 through 345 which should be the same chassis as your set. We sell used parts this is a working tv with a cracked blue tube were selling it as a complete chassis or individual boards on our site. Let me know if you may be interested. Chirping comes from the deflection circuits possibly flyback related.
Mar 05, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
337 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
