Question about Epson Office Equipment & Supplies
CD/DVD tray stuck all the way in my Epson photo R340 printer.
While inserting the tray to print on a CD the tray has stuck inside of the printer and the error message that I get is.
The CD/DVD tray is not set correctly.
Reload the tray and press start to continue.
But I can not reload the tray as I said because it is stuck inside the printer.
Please help.
Regards.
SOURCE: Epson Stylus Photo R300 CD/DVD Tray
Mine did the same, whilst they are very, very fussy the main problem is that you need a few inches of clear space at the rear of the printer when you print CD/DVD because the tray has to be able to pass out the back of the printer before being drawn back in.
Posted on Sep 30, 2007
map9966
  • 2351 Answers
SOURCE: epson R340 cd tray print problem
You CD tray has a problem. Contact Support at this link.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=60586&prodoid=58654762
Posted on Jan 31, 2008
SOURCE: Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Posted on Apr 15, 2008
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Posted on Feb 27, 2009
  • 173 Answers
SOURCE: installed epson r340 drivers from epson website -
install PRINT CD software from r340 installer. Just give your yahoo ID i'll send you the right software.
Posted on Mar 02, 2009
I would like to print direct to a DVD and a CD on a epson stylus
download new drivers for the R340 andthere will also be printing software attached to the drivers
Jan 02, 2010 | Epson Stylus R340 InkJet Photo Printer
Dvd/cd tray same problem as others posted here
My experience (with the R280) MAY have some relevance.It turns out that, should you turn the printer power on WHILE the output tray is in the upper (DVD/CD) position, you get an undocumented pattern of error lights, error message, and no ability to print. The cure (for the R280) is: just move the tray to the lower position and leave it there long enough for the printer to complete its power-up cycle and initialization, after which the green POWER light will be solidly on. Then you can shift the tray to the upper position for DVDs, or go ahead and print on paper where it is. Epson "technical" "support" people all deny that this is the way it works, and they want me to return the printer for replacement. I have confirmed the behavior on TWO different R280s. They also deny that their CD-Label software scatters "CDLabel.alb" files whenever you load a photograph as background, but that's another issue, and fortunately non-fatal.
Jun 20, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
I cannot get my epson stylus phot R340 to print cd covers properly - it is loaded but prints the wrong area
under the printer settings pick tray 2 then pull down the list select cd/dvd, should do it, regards mark
Jul 10, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
