Question about Garden
Sears Model 358.791070 Trimmer Overheats and then locks, unable to pull string to start. I allow it to cool off but it's still locked.
  • amontemayorj Jun 17, 2009
    I'll give that a try and let you know if your tips worked. Thanks.
    Scholar:
  • 81 Answers
Possible the fuel was too lean or something managed to enter the piston area through the air filter and locked it up. Possible scratching on the piston.. Time for a new trimmer.
Posted on Jun 17, 2009
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 25, 2009 | Garden
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Load new line onto the mighty vt26 17" curved trimmer
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
Jim
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 26, 2009 | Garden
Describe string replacement Troy- Bilt TB5755SS
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
