Question about Kenmore Washing Machines
Kenmore model #417 40042990 Front Load Washer is not spinning anymore. please help House FULL of kiddos and wife just laid off!!! Need to get working. IT also might not be draining... cant tell cus the spin worked wonders getting clothes almost dry. Also have a squikey Dryer... 417 80042990
  • 109 Answers
I would firstly take the back cover off and check the belt has not come off. Then check that the drain pump is not blocked.
Posted on Jun 16, 2009
Kenmore washer model #796 front load washer - washer will not spin out - went to drain water from drain hose - no water will come out - so I unscrewed pump filter - water is pouring out of there - help
OK....I am here to RESCUE you...1st, DON"T do that anymore! You will get wet! LOL. Simple solution. You need a New Drain Pump replaced and installed. Once that is done. I do NOT want to hear about you going down there anymore and doing....That! LOL...
Your machine will be happy and spin.and drain all day Long!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 05, 2014 | Washing Machines
I have a kenmore elite washer model 26962502. It makes a loud banging noise on spin and turns slowly. What has broken? Underneath it looks like two pins have come out and fallen into little plastic c
Yes , it is possible that the heavy load could have made the suspension soft or the drive shaft could have shifted or damaged.
You need to remove and check the bearing and suspension ,
click this link: Bearings
Jan 25, 2013 | Kenmore Washing Machines
We have a Kenmore washer machine top loaded model 110.44722401.The washer doesn't spin and doesn't finish all the processes.NOW THE WASHER IS FULL WITH WATER. WHAT WE HAVE TO DO?.........
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Kenmore Washing Machines
Hi, My kenmore front loader washer (C44072) doesn't drain after the wash cycle. The drain pipe is straight and full of water. I have noticed this problem earlier. Before I was able to force the drain by...
check for a kink drain hose are you have lint clog up in you pump ,you have to take the lower front panel off to see the pump depend on your model.you may have the pump in back of your washer.
Apr 25, 2010 | Kenmore 43142 Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
Won't Spin after wash cycle
Does it have a code...the access panel in on the front..above the drawers..screws are under so look for them...also go to their web site Kenmore.com and the have a help section.
Apr 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore washer wontt spin or empty. i laid machine on its side
Adjust the motor mount so the pulleys are aligned.
Brute force may be necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer Impelling into Hot Water Line
this sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer smells
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap.
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
909 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
