Boating Logo
Tim Ewing Posted on Apr 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where are the engine codes located on a 1970 Pacemaker 45' boat. Where are Boat Identification codes located on pre 1972 boats? Specifically this Pacemaker?
Pete Kop
Level 2:
Scholar:
New Friend:
  • Expert 61 Answers
  • Posted on Jun 15, 2014
Pete Kop
Expert
Level 2:
Scholar:
New Friend:
Answers
61
Questions
0
Helped
9821
Points
162
With a boat 44 years old, your boat engines may have been replaced or at minimum, overhauled. You might resubmit your question with some easy information you can add:
Gasoline or diesel engines?
Many were Crusader engines & you can usually see the name like this on the top portion of your engines.
You can see what color the valve covers are (blue, black, etc.).
You can see if they are V-8 engines if they have two long valve covers on top.
Most engines have a name plate on them (yours may be gone if original engines). Any mechanic you run into might find it quickly or recognize the engines.
Enjoy your boating. Pete
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Apr 14, 2009
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
fordexpert
  • 5692 Answers
  • Posted on Apr 28, 2009
SOURCE: looking for location of impeller on a inboard
If it has a OMC or Volvo most are in the top of the outdrive. If your motor looks like a car engine it can be if the front just like a car. This website claims they have online access to repair manuals so I would look there first. Go to other websites and look for impellers with the brand of motor, like Volvo impellers, Mercruiser impellers and some of those sites have excellent parts diagrams.
Anonymous
  • 86 Answers
  • Posted on Aug 09, 2009
SOURCE: I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
Anonymous
  • 53 Answers
  • Posted on Nov 01, 2009
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
fishdoctorfi
Shannon Currie
  • 178 Answers
  • Posted on Jan 01, 2010
SOURCE: have everstart 24dc-6 boat battery is it 6 or 12 volt
Sounds like the Batteries we used in golf carts......Deep cycle and shoe is right 6 volt.
I have a 14' MirroCraft aluminum fishing boat. The serial number is H14-2747, I need the model and year. How do I find that?
Question edited for maker name MirroCraft not 'Mirror'.
Ask them about the model. If it wasn't a 14 foot boat, I would have said the H14 was 2014, and then I remembered mine starts SS15- and the HIN.
However, this question has obviously been asked many times before. The 'H' code is 1968.
How can I determine the model year of my MirroCraft boat?
This all depends upon the age of the boat, but after 1973 your MirroCraft serial number will start off with "MRR" and the last 2 digits of the serial number will be the year. For example, MRR00000H399 would mean your boat is a 1999 model. The picture below is an example of a 2014 serial numbered boat.
Also here is a reference for boats made earlier then 1973, serial number starts with:
A=1961
B=1962
C=1963
D=1964
E=1965
F-1966
G=1967
H=1968
I=1969
1970, 1971, 1972 are very hard to determine.
Please email us your serial number for anymore information about it.
MIRROCRAFT - Wisconsin's Best Boats - MirroCraft Boats ...
https://www.mirrocraft.com Looking for that perfect boat? MirroCraft offers a full line of high-performance boats. Whether your lifestyle includes competitive fishing, family skiing ...
Outfitter Series Fishing Models · ‎Troller Series · ‎FAQ
Jun 08, 2022 • Boating
1helpful
How old is Grumman 16 ft with CSS on side. Where is the vin number
Hello, Dianne -
Boats have been required to have Hull Identification Numbers (HIN) since 1 Nov 1972 in the USA.
Go to this web page to learn where the HIN should be found on your Grumman boat, if it was made on or after 1 Nov 1972:
http://www.hinsearchplus.com/hs_userguide.aspx
Once you find the HIN, the information on the web page should help you determine when your boat was made.
Best wishes.
Jan 08, 2019 • Boating
1helpful
Am looking for users manual for a 2011 Starcraft Star Step deck boat.
try here
http://www.boats.za.net/boat-specs.aspx?boat=Starcraft-Marine-Star-Step-220-I/O-2011&bt=16894
Jun 08, 2018 • Boating
2helpful
2answers
What size motor for a 1970 15ft. seaswirl boat
outboard??? you could go all the way to 40 hp but id not recommend that much , but maybe a 20 hp would be just right !! its all about the condition/design of the transom and how you want the boat to sit in the water (weight) at rest ive seen motors as low as 10 hp on boats this size
Feb 29, 2016 • Boating
Wiring diagram needed for my 1972 johnson 50hp hydro-electric drive outboard motor
I don't have the diagram here, but it should be mainly color on color.
I'll look for a diagram if you couldn't get out.
User manual for 55hp Suzuki
does the bulb get sucked out ?
if it does right at the tank there is a valve that have a little marble you just have topch it back or change the gas coupler that have the valve
3helpful
Jul 09, 2009 • Boating
Balt 25 ft cabin cruiser batterys
To locate the batteries, all you need to do is follow the large red cable from either the starter motor or the battery switch. In both cases they will lead you to the battery.
I have been in the boating business for a long time and never heard of a manufacturer named Balt. To verify who built your boat, look for the Hull Identification Number. It is a 12 digit combination of letters and numbers located on the transom, or back of the boat. All boats built since 1973 are required to have this number. Once you have the HIN go to this link:
www.uscgboating.org/recalls/mic_database.htm
At this website you can enter the HIN and find the name and address of the manufacturer.
Jul 25, 2008 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
