Question about Toshiba Tecra A3 Notebook
When I start my laptop, I dont see the startup from Toshiba and the computer monitor does not turn on. If I bang the computer hard, i see the toshiba startup and the monitor turns on.
  • itsmeblock Jun 16, 2009
    Thanx for the quick reply anjana03 and Geekman. Aajana03, there's no point of using F12 and other key when my monitor is blank, it just doesnt work. Anyway, I tried thank you. Geekman, there seems to be no error with my LCD I guess. There no picture flickering or screen flashing. What I'm guessing is some kinda connection error, but I couldnt solve whether its LCD connection or other connection which relates to monitor or generates power to monitor. lol im just confused.
  • Toshiba Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 16, 2009
  • Chris Hingee
    Chris Hingee Jun 16, 2009
    Can you hear the hard drive spinning and the computer appears to be running but you you get a blank screen. If you look at the LCD screen at an acute angle and you see a dim image. then you have a backlight problem.
    To determine if you have a video card problem or a lcd screen problem, Connect an external monitor to your laptop and power the monitor up first and then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
    If you can determine the LCD is at fault then
    refer to my previous solution for information on service and repair.
    Sergeant:
  • 361 Answers
In my experince many causes do this as 1/ some time bious setining may be change automaticaly- re stat and press f12 go biouse cnoose hard first and chose cd room second then press f10 to save and exit.2/ running programme may be crash re install it.3/ you changed high graphic so screen is black adjust it .... thanks
  • Roshan Rijal
    Roshan Rijal Jun 16, 2009
    in my experince many causes do this as 1/ some time bious setining may be change automaticaly- re stat and press f12 go biouse cnoose hard first and chose cd room second then press f10 to save and exit.2/ running programme may be crash re install it.3/ you changed high graphic so screen is black adjust it .... thanks
Toshiba laptop makes a lound alarm at startup
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 28, 2013 | Toshiba Satellite Computers & Internet
Toshiba slow start up
if you dont have an anti virus then you might have a virus if you do you might have to delete some stuff off of your hard drive if that doesnt work then you might want to do a reboot it DO NOT DELETE YOUR SYSTEM 32 you will not be able to start your computer.
Nov 23, 2012 | Toshiba Satellite E205-S1904 Laptop
Why do i have an intermittent problem with my laptop freezing up during startup? startup?
You may have a bug. You may start by going to control panel and see how many programs are trying to start up at the same time. When my laptop does that I normally go to the control panel and stop programs and keep them from turning on at start up. you really dont need all programs to start up at the same time. This may cause freezing and longer times to start at start up.
Dec 31, 2011 | Toshiba Satellite A665-S6086 Laptop
I have a toshiba a305 it turns on says toshiba then just turns black still on all lights and fans but just a black screen
Your system is not producing video output after the POST, which means the Windows video is messed up or there is a problem with a component like memory.
Because you can see the Toshiba splash screen, it tells you the LCD screen is fine. At least you know the LCD screen is working. See if you can get into the CMOS setup screen. I think it may be by pressing F2 on startup. If you can get to that, make sure the hardware is correct (like seeing if your hard drive is seen as installed).
You can also try to press F8 on startup and start the computer in safe mode. Very possibly something is trying to start when Windows starts and not completing its startup.
May 23, 2011 | Toshiba Satellite A305-S6863 Laptop
My Toshiba lab top is not working and will not open up to windows. It says startup repair is checking your system for problems Startup Repair cannot repair this computer automatically Send more...
i would do a system restore on the computer backup what you want then when ready turn off the computer when of hold the zero key while holding it turn on the laptop this should start the system restore
Nov 03, 2010 | Computers & Internet
I have a Toshiba-M35X-S163 lapyop which worked fine for years, now when I try to boot up, the hdd light comes on, the fan turns on, but after 2-3 seconds, the computer shuts down. The battery, power supply...
Hi having hard time with your Toshiba laptop conserning your HD.
let me help you.... First wile you turn on your laptop press and old F8 Key then on the screen choose safe mode that will start your laptop on safe mode., to perform a disk cleanup... Also check your bios battery see if it dead.. again you re start your laptop this time you press and hold F1 or F2 key that bring you on the bios of your laptop., now look carefully in your bios .. press on default setup that will reset your bios for now.. then restart your laptop
then at the begining it will ask you wich mode you want ...then chose last good start.. If that solution dont work ..Then you may have to re install your windows again in your laptop, due to missing file in your startup windows., To install a new window,, again.. insert a valid windows with a serial key into your laptop.. wile your start your laptop press and hold F12 then wait for instruction...
good luck
Oct 20, 2010 | Toshiba Satellite M35X-S163 Notebook
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
I need to restore my toshiba l305 s5955 laptop using the hidden partition,but dont remember how to do it.
If you're using Vista, go into Recovery mode (or Startup Repair). In the options you'll have Factory Restor. Do that and your laptop will be restored to factory state.
Sep 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
Screen won't start
Hi tomasbaldry
My 1st (Routine) Question is:
(01) Do you have *ANY* other information *at all* regarding this issue?
For example:
(A) Research that might have already been done on this issue
(B) Things that might have been tried to determine or to correct the issue
(C) *Any* other issues w/ your computer - particularly any issues that corresponded w/ the onset of this issue.
(D) Something someone else might have told you, suggested or recommended regarding this issue (including contact w/ the manufacturer).
I guarantee you, you cannot give us too much information. The more we know about this issue, the faster and more accurately we can get it diagnosed for you. :)
NEXT:
We'll need to determine if the problem is w/ your computer's LCD panel (monitor).
The most direct way to do that is to connect an external monitor to the laptop (there is most likely a monitor connection on the back or a side of the laptop.).
(02) Connect a *known working* monitor to the laptop's external monitor connection.
(03) Turn the monitor power on.
IF you can do the following w/ the laptop monitor in the closed position, please, do so.
(04) Turn the laptop power on. (Make sure the A/C adapter is connected. (We don't want to confuse the issue w/ a low or dead battery.)
(05) Quickly but gently, (right after pressing the power on button) place the laptop's monitor in the closed position.
(06) If the laptop's LCD panel has failed, we would expect you to be able to see your laptop's display now on the external monitor.
If that is the case then the monitor either needs to be repaired or replaced.
That is the 1st phase of the trouble-shooting process for this type of issue.
(07) Please, post back here w/ the results of your test and answers to Questions (01/A-D). Please, include questions, observations, etc as well.
** Please, don't rate the experts' solutions
** yet. Instead, wait until this issue has
** been resolved or diagnosed and you don't
** have any further questions for us. Once
** you enter ratings for the experts' feed-
** back ("solutions"), the problem will be
** closed automatically. We won't be able to
** continue to assist you.
** As long as the problem remains open, we
** WILL continue to work w/ you on it until
** it is resolved or diagnosed.
Thank you,
BJ @:)
Apr 12, 2008 | Toshiba Tecra A3 Notebook
Toshiba Satellite A105 PC Notebook
When you turn it on, do you hear any activity? Motors start working, fan spinning, etc…? Try to connect an external monitor and start the laptop. Check if you can get any video on the external monitor. If the external monitor is dead too, try to remove the battery and start the laptop from the AC adapter. It also might be a bad memory module or a bad connection between the memory and the motherboard. Try to reseat the memory module, move it to the second slot. If you have two memory modules, try to remove them one by one and turn on the laptop. Also, try to remove the hard drive and see if you can boot it to Toshiba screen without the hard drive installed.
There is no special button to reseat the BIOS settings. To do it, you’ll have to access the BIOS using F2 button on the laptop start up, but as you have no video, you cannot access the BIOS and set it to defaults.
I
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Toshiba Tecra A3 Notebook Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
