Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
I have a saeco incanto i have the 2 green lights on the right flashing suggesting the machine is heating up and the red water light below this also flashing suggesting the system needs to be primed. i have primed machine and waited 30 mins for machine to heat but it wont. i have turned off/on any other ideas
    President:
  • 1,618 Answers
Open the water valve until it turns off the light, if you go through half the reservoir and it does not work, then the water circuit is clogged.
Posted on Jun 18, 2009
I have a Saeco Incanto S Class rondo I think it is an older version as very manual no computer. It has a flashing red light on left side (where coffee comes out) it has a ~~ on it. The machine still...
That light indicate that you need to change the water filter in the tank. The water filter is either an Aqua prima
or intenza filters. If you are not using the filter I would suggest to just reset the light. You can reset the light by holding down the water button under the coffee brew button. Looks like a water drop.
You can also download the manual at www.CeriniCoffee.com
Apr 11, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water...
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Aug 29, 2010 | Saeco Incanto Classic Espresso Machine
Load the circuit
Hi
It means you need to prime the lines. Push the button for water, then open the knob on the right. When water starts to flow the red light should disappear, and start to warm up. If the red light doesn't disappear, you may have a restriction in the flow meter, or intake line.
Nov 08, 2009 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto
Hi
Jul 01, 2009 | Saeco Incanto Classic Espresso Machine
3 flashing lights stay on all the time?
I have the same problem. It seems that the group motor issues. I ve opened up and found the group motor is coming some sparks. I know very well Saeco Magic Cappucino , Saeco range is more or less the same, Saeco incanto, first time deal with it , somebody just brought it to me to check it. I might fix it if find parts for it.
Load circuit means a lot, flow meter, pomps, could be the electronc board, bewing unit blocked up with coffee, so basically there is no water in circuit water or is air in water circuit....You have to check everything,
Mar 01, 2009 | Saeco Incanto Coffee Maker
Saeco Incanto Rondo - Lower LEFT Red Light Flashing
Its been a long time since I posted but I just had to answer this one. :)
The left one is a indicator that its time to change your waterfilter,
If you dont have a waterfilter or if you have just changed it, press and hold the steam button for about 5 seconds and then the red light should go way,
Dec 29, 2008 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
592 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
