Question about Epson Stylus R250 InkJet Photo Printer
Photographs colortones are not as per color corrections
Despite of head cleaning
  • 53 Answers
Try replacine the print heads
Posted on Jun 16, 2009
When I print color cards, the color prints in stripes. I have already let the printer clean itself.
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 13, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Green tint on flash photographs
without color correction software on your pc, you may get green tint from the flouresent flash, or use a "filter" over your lens.More expensive digital cams correct for this, back in the 35mm days, I had color correction filters I interchanged during shooting under other than daylight conditions,i.e., incadescent; flourescent;ect.
Jan 27, 2010 | Moultrie MFH-DGS-100 Digital Camera
Despite print head and nozzle cleaning, and a new epson color cartridge my Epson Stylus color 880 wont print in color. I've ran the software utility for head and nozzle cleaning as well as using the...
In desperation tried another new cartridge and it worked perfectly first time: I suspect the first was faulty so off to retailer for refund ASAP. At 30+GBP they dont come cheap!
Oct 22, 2009 | Epson Stylus 880 InkJet Color Printer
The photographs from my Cannon S900 have lines running vertically down the picture. I have used Deep Cleaning. Where can I get a service in England. Regards - Trevor Young
Hi Trevor, if you check Canon's website they have a service centre run by a third party. They are pretty quick but not exactly cheap.
Have you done a head alignment print? It may be that the alignment is off and that's causing the line.
Do a nozzle check and see if any of the horizontal lines are missing anywhere (they are not meant to be straight - in case you were wondering).
I could be that despite your deep cleaning, one of the nozzles is not firing.
Oct 15, 2009 | Canon S900 InkJet Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Brother MFC5440CN - Yellow cartridge does not print despite being
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Jan 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Lines on photographs,
try cleaning your printer heads in your printer settings in the control panel. might have to do it a few times and it will use your ink.
Oct 01, 2008 | HP Officejet 7210 All-In-One InkJet...
My Canon i455 will not print black ink
Hi , try to clean head until the black color will complete visible .clean also the ink retainer or tank replace with clean absorbent.
May 09, 2008 | Canon i455 InkJet Photo Printer
Many lines on photos despite numerous cleaning, deep cleaning
it could be a faulty printer head in the printer or purged unit not work correctly to clean the heads. you need to do a deep head clean then try printer head tested again. may need to do this a couple of time. still have problems get a new printer head for the printer.
Sep 25, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Epson Stylus R250 InkJet Photo Printer Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
