Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Tv
We recently received a used sony trinitron tv.  When I first hooked it up to cable, it worked fine.   I just recently rearrnaged our furniture, and, in the process, unplugged the trinitron, and plugged it back in.   When I went to set up, to switch tv to cable tv, I can't access it.   The remote doesn't have a menu button, but if I use the PIC MODE button, I have the audio menu on the screen.  All the remote lets me do from here, is change the MTS from SAP, MAIN, or MONO.   Can you help me?
  • sammy5 Nov 09, 2007
    Thank you!
    Problem Solver:
  • 20 Answers
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Posted on Nov 08, 2007
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Trinitron, no sound for TV but sound with DVD.
it could be the signal strength for your cable isn't strong enough. alot of people are encoutering similar problems ever since the digital switch over
Mar 27, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I also have a 27 inch Sony Trinitron and only nget
Just for the heck of it, check to see if the SAP setting is correct in the Audio selection menu. It should be set to Stereo.
I hope this helps,
Skyassoc
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Connecting DVD/VCR to TV
I called Sony and they guided me through it and all works fine now TY
Mar 19, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there?...
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
Feb 21, 2009 | Sony Audio Players & Recorders
Sony trinitron XBR2 32 " can't seem to get the cable working on it
You can hook up to either aux or vhf not converter. then with remote use ant button to select the one you are connected to. then do the auto search. Also can you get to 3 by pushing 3 and ent on the remote?
May 18, 2008 | Televison & Video
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Trinitron 32" TV
Switch the antena button on the remote
Sep 08, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
563 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
