Question about InFocus ScreenPlay 5700 Multimedia Projector
I have a infocus that produces pin hole lights on screen
I have a infocus projector which I bought in October 2008 - Last week I noticed the picture on my projector had a very small almost pin hole light. Since this time I have now over 100 no's of these samll pin hole lights overe the picture at random.
Can you help me to understand the porblem and the soloution - the bulb shows about 1000 hours use
  • 22 Answers
Yes it sounds like the LCD controller has died or dying if still under gaurentee take it back if not it wont be worth repairing.
Marc Engineer
Posted on Jun 18, 2009
I just bought a infocus in2102 projector but when i turn it on nothing comes up on the screen
check if any of the lights on the top come on (lamp light) and that the power light is green.
it may be a defective lamp that infocus should replace
Feb 08, 2011 | InFocus In2102 Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    I have a Infocus Screen Play 5000 bulb has 324 hours the picture is light green.
    try reflashing the firmware, check your cables by wiggling the ends coming out of the projector and watch the picture for any changes, if it goes to normal at any time, your cables are just worn out. if that doesn't do the trick, maybe your lcd polarizers are burnt, i really need a better description of the picture.
    Apr 01, 2010 | InFocus ScreenPlay 5000 Multimedia...
    Loosing picture
    replace the light tunnel
    Mar 27, 2010 | InFocus X1 Multimedia Projector
    The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
    Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
    Please describe the picture or post a picture of the screen if you can.
    Thanks,
    Dan
    Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
    The color wheel on my infocus 7200 is bad and getting worse.
    Have you cleaned the inside of the case out? It may be dusty and dirty. UNPLUG FIRST! If you can carefully remove the cover and inspect. Use a vacuum in reverse or canned air to blow out loose dust and debris. Clean or replace any projector filters.
    Sep 10, 2009 | InFocus ScreenPlay 7200 Multimedia...
    Bulb not firing
    yes. the lamps are good for 1500-2000 hours. with the projector on, go into the menu and find out how many lamp hours have accumulated.
    Jun 24, 2009 | InFocus LP70+ Multimedia Projector
    LP600 - Grainy picture, very poor quality
    Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
    In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
    I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
    I reassembled & started the projector and the image was back to normal.
    Jul 19, 2008 | InFocus LP 600 Multimedia Projector
    Tunel de luz
    Last time I checked, the light tunnel was available. It is a special order and cost $52.80 plus shipping.
    Infocus has discontinued parts for a number of their projectors. If it is still available, it could take as long as 4 weeks.
    Apr 17, 2008 | InFocus LP 600 Multimedia Projector
    InFocus ScreenPlay 5700 Multimedia Projector Logo
    225 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
