Question about Electrolux AW1001 Washer
Electrolux EW1045F, water filling stops at half level, not full
Electrolux EW1045F, water filling stops at 1/4 level, not full. adjusted water level switch, but no use, very disappointed.no block in the inlet hose, water pressure is normal.
unable to wash with 1/4 level of water, clothes are dirty even after several wash, can not raise the level by adjustment.
any idea? any advise?
your assistance much appreciated, thanks.
  • 109 Answers
The pressure tube from the bowl could be obstructed. You will have to remove the tueb from the pressure switch and blow through it to see if it's not blocked firstly.
Posted on Jun 16, 2009
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
Water not stop ovefill soap box
Sounds like carpet fibres have blocked the top fill hose on the conditioner section - so water doesn't enter the machine by the normal route.
Remove / clean / check the soap drawer - you may need to remove the top fill hose. If water is running but the level isn't getting higher in the machine this will be the problem, not the level switch.
Aug 10, 2017 | Electrolux EIFLW55HIW Front Load Washer...
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
Jan 28, 2011 | Toto Drake ADA Compliant Toilet with...
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
Washing machine Water level will not fill beyond half full
if this is a commercial. thats as much water it gets. most of them are energy star
Feb 07, 2010 | Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Short water flow time
If it's new you should call for service. Ask the technician to turn the water level switch set screw so it will stop filling at a higher setpoint rather than stopping at the edge of the gray cylinder baffels.You are aware the factory water level switch is pre set for low level because of water restriction regulations for manufacturers.But that means nothing for me if my laundry is comming out still dirty.. Much later and after much research i turned the water level switch set screw under the lid clockwise a half turn to have my WM0642HW fill up to the lower door seal to tumble in some water.How it was set before resulted in terrible wash performance especially with full loads! Forget it! It was WICK washing instead of tumbling in some water.Since i made the adjustment on the water level sensor the washer is 100% better than before.Trust Me!
Apr 12, 2008 | LG WM0642H Front Load
Electrolux AW1001 Washer Logo
383 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
