Question about SMC Netgear 8Port Gigabit Ethernet Switch 10/100/1000 - GS608 [ Netgear GS608NA ] (114635)
I have 3 computers connected by D-Link router. Recently I found that the router was not working so I bought a netgear GS608 router to replace it, but I can't find the cd or instruction leaflet so I have no idea how to set it. The desktop computers operate by window, the internet service provider is Optus, and is cable internet. Can anybody help?? Cheers!
  • 428 Answers
The thing is that this is not a router as I know. It has to be a switch. As I know.
You still need a router to connect to the internet and do the routing. First check that.
To configure the network, you have to connect 3 PCs to your switch. Connect the switch to a router. Use router's uplink or auto sense ports. Connect both the ports with a straight through cable. If you don't have such port in the new router (when you buy, check it first), use a standard ethernet port. But you have to use a cross-over cable. Then go to router's login page and log in. Set the dhcp. It will assign adresses to your switch and PCs also. Make sure you don't have static configurations in you machines which may confuse by duplication. To use dhcp, set you machines' IP settings to obtain IP and DNS automatically. Set the default gateway IP as the router's IP. Then open a command prompt and ping the router. Then ping the switch(first do that). Then ping other PCs. After verifying the connectivity, plug the cable(internet) and your router has to have such a port. Go to WAN settings and do any other configuration. Cable internet (if its adsl instead of TV cables), you will required to provide authentication information with other settings. For cable internet instead of ADSL, the configurations might be different and I don't have experties on that (cable TV used as a medium to access the internet). So hopefully this will do your task.
If this solution is able to solve ur problem, please rate it. Thanks and Good Luck. :)
Posted on Jun 16, 2009
  • Tharinda
    Tharinda Jun 16, 2009
    Well that's a switch as I know. So you still need a router to connect to the internet and also most importantly perform the routing.
    You can connect the switch to a router using a port. Any ethernet port will do but make sure to use an uplink port or an auto-sense port and use straight through cables(if you use regular cables you have to click the uplink button if its there). You need some cables if you don't have those ports and are known as cross over cables (to use ehternet to connect switch to router). Then you have to set up dhcp using your router. It may be assigned automatically. Make sure if you use static addresses, in pcs, not to duplicates those with the use of dhcp.
    Then you can test the connection. Get a command prompt, type ipconfig /all
    You will see th address of the router via default gateway if its set hopefully. Or log in to router and check IPs. ping all the IPs and check the connectivity. And then if your router(old one-if it can be used still) supports cable inputs, plug it in. Then the router will automatically detect the settings. Then use the WAN configuration of the router to do further configurations. Cheers!
    If this solution solves ur problem please rate it. :)
    Thanks Good Luck
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Feb 12, 2010 | Apple Computers & Internet
I have an Apple Mac connected to Netgear router. Partner has Del laptop which she wants connected via my router. Bought D Link 1005D switch but don't know how to connect both of us thru it. Do I need set...
What type of Netgear Router you are using?
If you have more than one ethernet ports to your Netgear Router, then connect your switch with a patch cable to the Router. Switch on it and check.
So that can share the resourses.
Dec 28, 2009 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Yellow Ethernet Cable
Ethernet cables can come in all colours (very unhelpfully). The cable you need has RJ45 connectors at either end, which are clear.
It goes by many names: you are looking for Cat5e or Cat6, ‘straight’ or ‘patch’ cable, which is used to connect, say, a computer to a router. Do NOT use ‘crossover’ cable.
Netgear has some info here (a little out of date but OK:)
http://kbserver.netgear.com/kb_web_files/n101561.asp
Jan 07, 2009 | NetGear WGR614 Wireless Router
Do i need a disk to install a netgear wireless?
You need a network cable (cat5e) to connect the cable modem to the wan or Internet port on the router. Then another network cable to connect the router port(1-4) to the computer's network (NIC) port. If you are going wireless, you do not need to connect the second cable.
You do not need a disk. just power down the cable modem,router and computer.
Hook it all up, then power up the cable modem first, wait 30 seconds, then power up the router, wait 30 seconds, then power up the computer. You shold be able to get online.
Unless: you are using DSL
and unless the original owner had an encryption key on the router.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2008 | NetGear DG834G Router
Netgear DG834v4 router No accesswhen downloading large files
All you need to do is lower down the MTU value of the router. By default it is set to Auto with a value of 1500. To reduce the MTU, open the router's admin page and look for MTU setting. Set it to Manual Value and set the size to 1492 if you have DSL internet, and 1463 if you have Cable Internet. 1400 for general.
Dec 02, 2008 | NetGear DG834G Router
The netgear router has problems connecting with the intetnet please help me
I have a problem here.
1) When i connected the modem to the computer, it works good.
2) I have more computer now, so i bought a router.
3) This time, when i plug in the modem to router and router to my 3 computers.
4) The local network is working but not the internet.
Any solutions? I have tried trendnet router, netgear. It's definitely not the router problem.
I have tested the same router in other ADSL line, it works.
Please help
Thank you
Aug 23, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
228 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
