Question about Epson Office Equipment & Supplies
Printer won't print lx-800.document pending.failed to print
Epson lx-800. OS windows xp.whenever i click on print or press ctrl+p the document appears in the printer iconmarked as printing but the printerdoes'nt print aftersome time the document is marked pending and after alittle more time error msg ''failed to print appears''
the printer cartridge moves a little whenever i on thr coimputer with printer on
the windows did not detect my printer automatically.i installed it manually
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Posted on Feb 20, 2009
SOURCE: lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Posted on Dec 07, 2007
SOURCE: Having problems deleting pending documents
@larryab:
Mate, thanks! I had exactly the same problem and your solution worked precisely as you say...
Thanks a million!
Posted on Jun 29, 2009
  • 202 Answers
SOURCE: Epson LX-300+ ''please insert paper'' error on Windows 98 system
try using an older driver from epson, sometimes you can luck up and find one that will work. try and find the prior model the one it replaced and see what happens. any of the 9x drivers should work try several just because one won't dosent mean another wont. hope this helps
Posted on Jul 16, 2009
MUKHTAR
  • 2022 Answers
SOURCE: epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Posted on Feb 15, 2010
Printer does not print on windows 7 operating system
Thanks for contacting Fixya.com.
As a veteran Epson user, I can usually find out just what Epson offers in the way of drivers for any of their printers, depending upon the version of operating system is requiring printer drivers. This is no exception with the Epson LX 300+.
Unfortunately, Epson only made drivers for the LX 300+ for Windows OS XP and earlier. As of current there are no drivers for PCs with Vista or Windows XP made for the Epson LX 300+.
Here is the link directly from Epson's Printer Drivers & Support page for the LX 300+
Epson LX 300+ Drivers & Downloads Page
If you truly need another Epson Impact Printer which is possibly windows compatible, I would recommend visiting the link below in order to find a more Windows 7 comparable model, if there are any.
Epson Support -Impact Printers
I hope this information does provide you confirmation of what you have been seeking for this printer model.
Regards,
-Mactectrainer
Aug 19, 2010 | Epson LX-300 Matrix Printer
Epson lx 300 dot matrix printer not printing properly
Feb 15, 2010 | Epson LX-300 Matrix Printer
Cant print, pending has no status.
Please check printer cable both end otherwise please replace the data cable.This is the only data cable faulty/ lose connection problem.
Jun 01, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Dec 10, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Driver problem
You may have to come to a happy medium on this printer, or, perhaps there is a dip-switch setting (on the printer) needing to be changed. You could also try one of the other Epson printer drivers. Perhaps you can find one which will get the desired results
May 01, 2007 | Epson LX-300 Matrix Printer
307 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
