Question about Printronix PrintNet Print Server
Printronix printer connected to scounix server
When the print command is given (more than one file at a time and sometimes even the first file) page from the perforation is not printed.pages are printed up and down.
Culd be a emulation problem or maybe spooler configuration
Posted on Jan 22, 2008
Printing barcode using font 39
The printer can get out of "phase" and the print will look shaky. These instructions are for the P5000 but the phasing process has not changed.
http://themrpsolution.com/v//vspfiles/Tech%20Tips%20Q&A/Printronix/P5000_phasing.pdf
Jan 14, 2016 | Printronix P7220 Matrix Printer
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Can the Printronix P7005 PSA3 print PDF files?
Sounds like your printer may need IPDS, I'll need to see a configuration page from your printer in order to determine whats on it. you can email me it at rcardenas@mrp.to
Apr 09, 2013 | Printronix LineJet® P7005 Printer
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
Printer not Print
logic crad have to change
Apr 17, 2012 | Printronix P7005 Matrix Printer
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
Dec 29, 2008 | Printronix Line Matrix P5210 Printer
Printer server
hi veeday you have to check the properties while installing a network printer if ur printer is compatible for that thing or not , but you can assign priority to user printer & ur printer will print for that pc first , path > go to the properties of n/w printer & set priority
Oct 17, 2007 | Microsoft Windows Server Standard 2003 for...
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Open Questions:
See all Printronix PrintNet Print Server Questions
Printronix PrintNet Print Server Logo
Top Printronix Computers & Internet Experts
David Payne
David Payne
Are you a Printronix Computer and Internet Expert? Answer questions, earn points and help others
