Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Horizontal dark smudges have appeared on the screen. Only shows up on light backgrounds. Cannot see them when TV is off. It looks like they should just clean right off. More of them are starting to appear. Panasonic Viera LCD Flat
  • mschipley Feb 02, 2010
    Someone did tell me that the reason is the backlighting is burning out. This TV does not have the LCD? or LED? backlighting. This one apparently has horizontal tubes like flourescent bulbs or something. I was told it could be fixed by replacing the burned out tubes. Don't know, haven't tried it yet. I am not very technically minded but I have someone who is going to try to fix it.
Did you find a solution to this ? i have a TV doing the same thing.
Posted on Feb 02, 2010
Can dark smudged look on screen be a pixel issue?
Might be. Contact any service technician and make it confirm.
Apr 29, 2013 | Sanyo DP46849 46 in. HDTV
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Dark run looking spot of screen
Probably a bad backlight tube. It would look like a darkish about 1" (2.5cm) wide streak running near to horizontal part or all the way across screen.
May 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
?Smudge on lens maybe? Shows up in pictures.
Hi!
Does the smudge changes / mooves as you zoom the lens? If so, the smudge is most likely on the focus lens, if not, there's something on the CCD. In both cases the lens will have to be taken apart and cleaned by a professional. I suggest you contact a local repair shop and see how much they ask for it.
Tom
Oct 09, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Dark spots on my JVC 61" tv
dark spot could be a faulty led. if you put a program on that is in white screen you should see all the leds light up the screen. dark spot will be were the led is not working. if on white screen and they all lite up but still dark around the area, it could be the lcd screen. and could be dying pixels. and try this video https://youtu.be/wlA2rcrAOCs
Feb 10, 2018 | Toshiba 55H70 55" Rear Projection...
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Apr 08, 2008 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
When the tv has been on awhile
Do the smudges move around or are they in the same position all the time??If they appear in the same position it sounds like you are having a problem with the invertor panel or the back light circuitry.If you could post photo of fault would be helpfull
May 11, 2007 | Panasonic TX-26LXD1 26 in. LCD Television
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
551 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
