Question about Bang and Olufsen Beosound 2000 Shelf System
CD starts to spin then stops
It has been hanging on the wall for a while. Tried to use it one day and the CD would spin a couple of times then stops.
Any ideas, comments?
Problem lies in the optical block. try cleaning with a CD cleaner. Might help
Posted on Jun 16, 2009
1995 Pontiac Grand AM SE. Heater fan works for weeks then won't go, try a couple hours later then it goes.
It sounds like the brushes on armature for (blower motor ) are worn. Sometime a bad spot on the armature from not being used often and also by being in the engine compartment where it is exposed to condensation. When the brushes stop at that particular spot, the blower will not start spin process unless it draws alot of current that may be why the fuse blew. You can remove the blower and examine or just make the change.
Jan 28, 2013 | 1995 Pontiac Grand Am
I have an Aiwa z650 3disc cd player,the disc spins a couple of times and then stops I'm told the potentiometer may need adjusting,I've taken the case of but can't find this thing
Not sure bout that ,,usally when it spins a few times and thats it,,motor wore out,,,put a disc in try as it stops spinning or right wen its fixon to start spinning given it a help spin,,i had that fix or getem goin,,,,also try tapping it ,,and hitting the side od the machine,,good luck,,
Dec 23, 2011 | Aiwa Audio Players & Recorders
When a CD is selected, it's starts to spin, I hear 2 clicks and it stops spinning. This happens a couple more times then the CD is ejected and returned to it's slot.
It sounds as though either your CD player (probably a CDM3 or CDM4S) of the CD control box is defective. I would be happy to help you troubleshoot further over the phone and can provide repair and/or replacement of the defective components. Please email tech@wurlitzer-ohio.com. Thank you, Rod Stebelton
Jan 30, 2010 | Wurlitzer Jukebox 1015 One More Time...
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
Dodge Ram 2500 Cummins Diesel 2001. Starter hangs up when start
Have you had a mot or try checking with an mechanic¬!
Jul 29, 2009 | 2001 Dodge Ram 2500 Truck
Clicking Noise
You have a broken drive coupling. This video will show how to cahnge it.
Mar 27, 2009 | Whirlpool Ultimate Care II GSQ9669L Top...
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. bigslimaba@yahoo.com
Jan 11, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Acer TravelMate 290 PC Notebook not starting
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Sep 24, 2007 | Acer TravelMate 290 Notebook
Panasonic SA-AK330
Change the spin motor disc
Jun 08, 2007 | Panasonic SC-AK330 Shelf System
508 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
