Question about T-Mobile BlackBerry 7105t Cellular Phone
I need your help
My blackberry 7100t says device error 365 with reset and it wont go past the white.
i tried by removing battery to re-inset but the problem remains
  • 2 more comments
  • Anonymous Nov 04, 2007
    blackberry perl device says jvm erroe 545
  • squirrel112 Nov 18, 2007
    my blackberry 7105t phone kepps saying there are errors and it keeps telling me to reset the phone sometimes it will show the hour glass but then it just says that there is an error is there anything that i can do to fix this?
  • Anonymous Apr 11, 2008
    error 365
  • zakir javed Apr 23, 2008
    my phone shows white screen and it does not start. It also shows abort exception rest. what should I do?
Take it to the phone shop. They'll do this flash thingy and it'll be up and running
Posted on Jul 02, 2008
My phone says JUM error 102 reset.. i click enter and it just comes back to the same thing..what can i do?
Posted on Feb 26, 2008
  • 4,102 Answers
You will need to take it to a phone shop and they will use a flash leed and reload all the info for you shouldnt cost to much to do their is no way of doing this yourself hope this is some help
Posted on Oct 31, 2007
My RIM Blackberry 7290 comes up with "Device Error: 365 Reset". Whatever key I push, it still comes up with the same message.This problem started after taking the battery out to insert a sim card. Tks
you probably either messed up your battery, scratched your sim card, or got something wet. i would ask a phone technician cause you might need some help.
Dec 15, 2009 | RIM BlackBerry 7290
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
Error blackberry 7100t
Cause:
Some of the boot up file has got corrupted
Resolution:
Re-install the handset software using Desktop Manager
Jun 09, 2009 | RIM BlackBerry Pearl 8100
Dvice error 365 reset
In alot of cases Device Error 365 means the unit is dead., it's not ever gonna work again.
365 is hardware error. Some cases it has been resolved with forced OS reload, but in many cases it's dead
May 31, 2009 | RIM BlackBerry 7290
Cannot reset
Try removing the battery for 30 seconds and trying again.
Failing that try to reset using ALT, SHIFT and DELETE
Apr 07, 2009 | RIM BlackBerry 8800 Smartphone
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Blackberry pearl wont go past the white screen with the hour glas
the only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
Nov 13, 2008 | RIM BlackBerry Pearl 8100
Blackberry 7100t
i just got a 7100t and the battery won't charge. i bought it used, so i don't have a manual. my computer says it does not recognize the device. Is there some type of hardward i need to download before it will work? thanks
May 29, 2008 | RIM BlackBerry 7100G Smartphone
Phone keeps turning on and off (had gotten multiple errors)
my blackberry 7100t was dropped and now the problem is its screen keeps on fading off and colours keep on changing again and again..the screen comes nack to normal if the screen backlight is switched off for around 5 min..it will work normally for sometime may be for ten fifteen min and the problem starts again..suggest some solution for this..and also if u could advice me from where i could get a new battery for the same phone..
contact:
madhur@priest.com
May 12, 2008 | RIM BlackBerry 7100t
7290 device error 365 help me
i am facing same issue error 365
Apr 09, 2008 | RIM BlackBerry 7290
T-Mobile BlackBerry 7105t Cellular Phone Logo
218 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
