Question about Magic Chef CMV1000B Microwave Oven
No power no time orday
No power no time or day
    President:
  • 512 Answers
Check the fuse, open front of micro, look for paperwork on wiring diagram, this tells all the working parts. Look for fuse, test to see if bad. If good, test all cavity switches there must be a bad one, replace and unit should work.
Posted on Jun 17, 2009
Digital button on kenmore microwave does not respond when pressed could this be a fuse or is key pad gone
Considering the problems you are having it would be cheaper to replace the microwave oven.
May 22, 2012 | Kenmore Microwave Ovens
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No power, oven is completely dead. On the day the oven quit I dropped my can opener on the ovens power cord coming out of the wall. This has happened several times before over the years because of the...
if you think that you have damaged the power cord check the fuse in the plug first, their is a fuse in side if you are still in problems come back to me
Jan 31, 2010 | Panasonic NN-T993SF Microwave Oven
Microwave not heating items, also range vent not operating
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and other parts of the unit have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, they dont make them long lasting anymore, they are a "disposable" product these days
Jan 14, 2010 | Whirlpool MH3184XP Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Too hot
I wish my m/wave was this powerful. try reduceing the time 1200 watts is a lot of power. may your used to a lower powered modal
Apr 13, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Magic Chef CMV1000B Microwave Oven Logo
192 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
