SOURCE: Refridgerator won't cool on propane.
I had a similar problem. The flue would get hot and the cooling tubes
would get "warm". The refrig would get a LITTLE cool but nothing to be
of any help.
I solved it though...it turns out there is a "flue baffle" (twisty
little metal thing) that is supposed to hang in the inside of the
baffle. It hangs from a screw found on top of the baffle and it is
supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a
coat hanger, then rehanging it using a new screw. That solved my
problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the
flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding
it. Item B is the screw that was corroded on mine, and ended up dropping
the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
SOURCE: I have a Dometic model
Most times when this happens the thermostat is the culprit, althou the control board may have a blown fuse. Check the fuses on the circuit board on the back of the fridge and let me know if they are intact. Then check the board for power both the AC and the DC side. Can I ask what pedistal your talking about?
