Question about SanDisk Sansa Clip MP3 Player
Sansa clip forzen and dim, not doin anything... HELP!
I was riding in the car and my Sansa clip turned off without me doing it , it had about 1/8 of the charge, but the funny thing was, the blue ring around the pause and everything was on, so I put it in the pocket in the car, went for a 30 min walk came back and it was the same. I plugged it into the comp 4 bout 45 min, did nothing but name the last song I was playin, no music, and very dim lighting. Then I plugged it into another comp, and it isnt doin anything, so I unplugged it and it got dimmer. I tried to turn it off but nothing happens... plz I need this thing for a 7 or 8 hour car ride home PLZ PLZ HELP!!!!!! THANKS!!
~SOAD4EvEr&PeAcE (-<)
Hey my Sansa clip do the same thing plz if there is an answer plz tolld me on my email thats it munna_loma@hotmail.com if u know any thing about it just tell me thanx :D
Posted on Jun 16, 2009
My Sansa Clip just stopped playing and shut down. I cannot get it to turn back on or to charge on my computer. This is the 2nd one I have had this happen with. What is the problem?
On my e260r, that happened while I was just getting done with a bike ride. Figured it was the humidity from being in a pocket. I simply fixed it by pulling out and immediately reinstalling the battery.
On my Clip+, the first bike ride that happened. I just held down the power button for about 20 seconds then tried to turn it on and that somehow fixed it.
Same case as yours... just stopped playing. Wouldn't respond to controls nor do anything when plugged into computer. Just dead. Try it holding down the power button and trying to restart and if that fails, do the battery thing.
Nov 03, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
How to fix an sansa clip mp3
You have bluntly said that the device isn't working but not the exact behaviour. Depending on it, try the following step, and if it works, well and good. Otherwise, let me know what exactly are you trying to do and what exactly happens...
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. Slide the Power switch up then release to turn on the player.
Feb 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
Computer not recognizing mp3 sansa clip
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e260 Screen is too bright
Cannot do anything else but adjust the brightness - the Sansa player has the opposite of the other player's problems - most players are too dim.
Mar 10, 2008 | SanDisk Sansa e250 MP3 Player
My SanDisk sansa e250 wont sync
try reseting it to factory settings. in other words put it into recovery mode. to do this simply plug it into your computer, then push the hold button down so the orange is showing. then push and hold the record button on the side of it and push and hold the power button. if you do this correctly it should work. heres a link to the sansa forums just in case http://forums.sandisk.com/sansa/board?board.id=e200
best of luck friend! : ) dont give up!
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
It froze
Sansa Clip Player has some problem. I tried 4 sansa clip players (I purchased at Best Buy for Thanksgiving), and none of them work. Dont even try to exchange them, just return them back.
Oct 24, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
181 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
