Question about Kenmore 22422 Top Load Washer
F51 comes out and the machine stops working. what can i do
F51 comes out on my machine kenmore elite top loader. what can i do
  • 15,935 Answers
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Can the motor sensor,motor and bearings be replaced at what coast?
Of course the motor can be replaced. I don't think you have a motor sensor on a top loader. What bearings are you talking about? Normally the motor coupler wears out many times before the motor goes bad. The coupler connects the motor to the transmission. Go to www.sears.com/parts and put your model in and you'll see all your parts.
Aug 28, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis he top load washer keeps stopping in the wash cycle, beeps and flashes a code F51...what does this mean?
from what i can find out it apears to be the rotor position sensor which seem to be a common fault it apears you need a new board to fix the problem
Aug 14, 2011 | Kenmore Washing Machines
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
