Question about Nokia 1100
There's a "TEST MODE" on my screen..
When i opened it, it appears.
    President:
  • 1,952 Answers
Swicth off phone 5 minetes
Posted on Jun 16, 2009
HOW TO REMOVE TEST MODE
check the sim card to be inserted well It should never open in this mode if it has the sim card inserted..Also check the screen when you open it ..if it asks to stop this mode..do it ..and start normal ..Another action is to remove the battery and start it again after checking the sim card ..and also pay attention to see the mode it opens ..
Dec 28, 2011 | Nokia 1650 Cell Phone
Test mode on screen
when i on my phone the test mode written appeared and then phone again become off.
Jul 30, 2010 | Cell Phones
Test mode appear on screen
TO reset ur normal mode u need ur data cable and a nemesis service suite wich u can download from the link http://rapidshare.com/files/140978321/nokia_security_code.rar. install the software,connect ur phone then open it
1)click scan for new device
2)click phone info
3)click scan button
4)now on right hand side select normal mode
5)click change
close the software and restart ur phone
DO IT ON YOUR OWN RISK
Mar 02, 2010 | Nokia 1208 Cellular Phone
I have the test displayed and it dosent matter
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and test appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Feb 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
My 15" LCD monitor TTX went to sleep mode and never return back
mike_garzan, Your monitor will need some work done on it!! Do you know the "flashlight trick" that every owner of an LCD monitor with "cold cathode-fluorescent-lamps" should know how to do when the BLACK screen of death makes it presence known? Do this test first! It is a very easy test to do. 1. With a KNOWN GOOD pc fully booted to the WIN-desktop showing on a GOOD Monitor have a friend tap the CTRL key on the keyboard every 30 seconds or move the mouse to ensure that the pc won't go into sleep mode. 2. Power off the good monitor and disconnect it from the pc. Now reconnect the TTX9151 to the pc and wall outlet power. 3. Then and only then turn on the monitor and make note of what happens. Did you see or not see the WIN-desktop appear?
4. Now for the flashlight test. Even though the LCD panel appears BLACK, shine a bright flashlight about 1" from the screen's lower left corner and make note if you can see the Windows START icon even though the screen appears to be BLACK. 5. Turn off TTX9151 or yank the plug from wall outlet, and disconnect from pc. TEST IS DONE. Reconnect good monitor to pc to get back online. The test was to evaluate the current status of the "switch-mode-power-supply" and the CCFL inverter circuit DC source. If you could SEE something on the BLACK screen then you know that half of the SMPS is working and sourcing voltage (+5 or +3.3v) to power the vga/lcd interface board! It also means that the SMPS is not in FULL SHUTDOWN mode and only has a problem sourcing voltage(+12v to +18v) to the CCFL inverter circuit which generates 800v to 1200v ac to light-up the CCFL's that are hung across the rear of your LCD panel to produce the WHITE LIGHT needed to see what is on the screen. Now, if you didn't see the WIN-desktop, then the SMPS is probably in complete SHUTDOWN mode trying to save itself from a CATASTROPHIC, NONRECOVERABLE failure! (eg. smoke and fire) Put the TTX9151 in a safe place and get back to me with results of the TEST. lmistyrel and on aim.com or do a comment to your original post above on fixya and I'll give you advice as to what you need to do about getting it repaired or other actions/options you as a consumer/user of LCD displays have open to you. Bye for now. 12fixlouie
Oct 27, 2009 | Elo TTX 9154 15 Inch LCD BLACK W/...
Test mode on nokia 1200
Test mode is used by engineers to repair particular problems with mobiles. It would appear you would need to take this phone to a mobile repair centre and get them to fix the s/w on it.
May 25, 2009 | Cell Phones
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
Not recirculating
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Nokia 1100 Logo
32 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
