Question about Sony KP-61XBR48 61" Rear Projection Television
Trun on tv and all i get is a red flashing light
My tv is a 1995 sony vidoscope xbr model 61XBR48 i paied a repair man $500.00 to fix it but never cameback he say something about sencer
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: I have a Sony XBR
Hi
Thanks for using FixYa. Please post a comment with the no# of times the light blinks so that I can further assist you.
Thanks
Rylee
Posted on Sep 19, 2010
walesarumi
  • 6993 Answers
SOURCE: Sony KP-61XBR48 Projection TV When power button
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 03, 2011
Sony KP-61XBR48 wont turn on
Hello!
You should open the tv and clean the cirucit using the blower and fix some connection. if this not work you should test your circuit for the faulty parts of the tv.
melnavz
Mar 14, 2008 | Televison & Video
I have a tv Sony Trinitron XBR. It does not turn on; the LED red light blinks 7 times.
Common problem on those. It has deflection stopped. I.C. on deflection board. Need shop to repair.
Nov 23, 2014 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Tv is in standby mode (red light on bottom left is blinking). we can't get it out of this mode. We moved the tv and unplugged it...tried to turn it back on and this happened.
I need a model or chassis no. (on the back of the TV). Also how many times does the light flash between the long pauses? Sonys have a self diagnostic feature that flashes the power light a certain number of times to indicate various problems.
Dec 04, 2009 | Computers & Internet
I have an old trinitron
What model ? I thave hree Sony XBR's and each of them have had various IC's that failed and needed replacement as well as some bad solder joints (from constant hot/cold cycles) that needed attention. It will take electronics knowledge and experience to diagnos and fix this issue.
Apr 16, 2009 | Sony Televison & Video
Red light flashing 5 times every 2 seconds
The 5 blink code in dicates a loss of video. There could be a number of reasons for this. I need to look up your specific model to get you the probable parts. Stay tuned...
Dan
Jul 29, 2008 | Sony KP-53HS10 TV
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Apr 18, 2008 | Mag Innovision InnoVision XJ 717 Monitor
Televison & Video Logo
176 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
