Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Lid switch replacement
I am trying to replace the washing machine lid switch and can't figure out how to get the top of the washing machine to swing open to get access to the switch to replace it. What am I missing? Anyone who has replaced the switch, can you tell me how to gain access.
  • byron_kehler Aug 07, 2009
    Unfortunately no, the washer is still unfixed. I have freed the lid in the front where it latches with the two clips, but it still will not lift up. It appears to catch on the assembly holding the dryer in place toward the back of the lid. There are plastic clips which attach the dryer to the lid, not sure what to do with them. Any help or suggestions would be welcomed. I am ready to call an service provider if I can't get more help. Good luck.
  • dlaifer475 May 11, 2010
    I have a similar problem - were you able to figure out how to open up the top of the washing machine to get access to the switch?
  • 365 Answers
Some washing machines have the bolts that hold the top down situated behind the front panel but you have to remove the panel to gain access.
There may be 3-4 screws at the bottom of the front panel, remove the screws and the panel should come out.
Hope this has helped
Posted on Jun 16, 2009
  • Harry Goodwin Jun 15, 2010
    On the bottom of the front panel there should be 3 screws holding the panel on, undo those screws and remove the panel, this should expose another 2 hex head bolts, 1 on the left, 1 on the right, undo both and remove, the front should tilt if you lift it at the front, you should have access to the switch now.
    Hope this helps, I had a Hoover 620 washing machine with this problem so that is what I am going off, yours may be a little different but I hope not too different for your sake.
My washer stalls at the end of the wash cycle and I can hit the lid with my hand to restart it
Sounds like your lid safety switch is bad. Replace the switch. If this is a unit with a hidden lid switch, left rear, you may only need tighten your lid hinge screws.
Jan 01, 2015 | Kenmore Washing Machines
Why does my washing machine beeps 6 times and does nothing
I found this
The 5 beeps indicates that the lid switch isn't being sensed*
The out of balance switch is separate to the lid switch on these machines. The 3 water level light does indicate the Out of balance switch as faulty, if it is accompanied by 15 beeps. 5 beeps means the lid switch = LD.
This is what I want you to do.
Open the lid up. Study the left and right hand sides of the lid while it is open. You should see a little bulge in the plastic on one side. From memory it is the left hand side when standing in front of the machine...
This is the magnet in the lid, when the lid is closed, it lines up with a sensor on the underside of the top hob of the machine.
If you stick your hand up underneath the top of the machine in this location, above the bowl, you should be able to feel the sensor and the wires going to it..
Sometimes these sensors fall out of where they clip to on the underside of the top of the machine. Feel around and see if it is hanging down okay...
If you cant find it, dig the plastic caps out from the top front of the machine where the lid closes against, undo the 2 screws, undo the screws across the back of the top of the machine and raise the entire top by gently* swinging the top up and back against the wall and then you will see what I am talking about.
Apart from falling out of where they clip into under the hob, the sensor can corrode away and fail. If yours looks corroded or bulging, it will need replacing..
This is where the problem is I'm thinking, especially if you have already replaced the out of balance switch and of course, the 5 beeps.
Try the above suggested and let me know how you go okay,,,
Any further questions, even after rating, just ask, I'm happy to answer them.
I can link you to a cheap parts supplier who ships nationwide fast and cheap if required..no problems at all.
Westinghouse washing macjhine Lt608s goto start beeps water
Feb 10, 2018 | Westinghouse Washing Machines
How do I replace the switch lid on my top loading Kenmore 80 series washing machine
first you have to figure out if the lid switch is the problem, it may not be.
2nd you should really get a repairman to fix your unit.. it takes experience just to open the covers.
Please rate/vote this response thanks
Dec 19, 2010 | Kenmore 24032\24036 Top Load Washer
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
Lid switch is broke and need to replace.
1. Unplug machine
2. Remove two screws in back of angled top part connecting it to base, lift back up 4-6" and shift top toward front 1/2" so tabs holding front of top to machine base can disconnect.
Mar 27, 2009 | Kenmore 24622 Top Load Washer
Washing machine tub is not spinning and holding water
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
If you have a hidden lid switch (no visible hole around the top where the lid closes) try tightening the screws on the lid hinges.
Jun 18, 2008 | Washing Machines
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Replace lid switch kenmore mod# 110.29902200
remove the two screws in the top of the console they will be in the rear left anmd right side
then flip up the console and remove the 2 spring clips and the lid switch molex plug the cabniet will come off tilt forward and pull out you will see the lid switch running on the underside
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
166 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
