Mitsubishi WS-55859 55" Rear Projection Television Logo
Posted on Jun 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Warped 3-D LOOK COMES AND GOES
ONCE TV GETS WARM IT WORKS FINE 55 INCH MITSUBISHI HD 1080 SERIES ABOUT 10 YEARS OLD
Dihaboluz
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2012
Dihaboluz
Contributor
Level 1:
Answers
Questions
0
Helped
358
Points
0
And that means?????????
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Jun 16, 2009
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1723360
Points
23750
Resolder the convergence ICs . Common problem with mitsubishi rear projections
2answers
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
2answers
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
SD TECH
13helpful
2answers
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
4helpful
Television screen bows downward. Kind of looks like its in 3d mode but it bends down like an upside down U. Also gets staticky, squiggly lines of diff color appear for a few seconds here and there. The...
If it looks 3d and will not adjust in the customer mode(convergence) you have a convergence circuit problem.
Get me the model number off the back--it should begin with a VS or WS or WT followed by 5 numbers and I will tell you what may be involved fixing it.
For most of the WS & WT series sets I have start to finish step by step instructions for this kind of repair.
If this information helped you rate this solution as I do this here for free.
SD TECH
1helpful
Same blinking problem with my 55" HD 1080 Series TV.
That model Mitsubishi is a 65 inch set not 55. And if the blinking you are talking about is the Power LED continually blinking green and otherwise dead it is because the digital module is not booting up. I have repaired many of them and this is done by replacing components in the digital module. Average repair cost is around $200 to $300 depending on where you live. That particular set is well worth the repair. If yours is a 55 inch instead the same still holds true.
8helpful
3answers
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
My Mithsubishi HD-1080 rear projection tv 65 picture warps and distorted when first turned on.
sounds like your convergence ICs are getting weak, or the solder may need to be touched up.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
