Question about Fujitsu Plasmavision 42" TV
Flashing red light no screen fujitsu plasma - Fujitsu Plasmavision 42" TV
I have no picture on my Plasma and I have a red and green flashing light. Does anyone know the problem and more importantly, can anyone recommend a fix?
Posted on Sep 07, 2009
  • Fishercahill Jul 06, 2011
    Did you find a fix as I have the same problem?
This is a temp fix I have done, since the TV gets hot I mounted another muffin Fan to the top left where the fan exhausts hot air. This has stopped my set from blinking RED for now. I am still looking into what board is going over load to cause this.
Posted on Jul 21, 2009
3 Suggested Answers
  • 534 Answers
SOURCE: flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Posted on Jun 04, 2009
  • 4 Answers
SOURCE: fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Posted on Aug 22, 2008
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
Fujitsu plasma screen went blank and the LED light which generally shows green (on) or red (off) is blank (no color) as well.
Usually when these develop a fault you will get flashing LED codes. If you are not getting any the power supply may have failed completely.
Try another cable and socket in the first instance and ensure the manual power switch feels normal in action.
Jul 06, 2009 | Fujitsu Televison & Video
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu plasma went blank
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu Plasma 42' approx 4 yrs old
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at all_ps2_sales@hotmail.com and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Dec 12, 2007 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu Plasmavision 42" TV Logo
1,935 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
