Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Sir every time I open my PC there's a blue screen appearing then it shuts down but sometimes when I log in it's OK and if I open any program the blue screen appears again then will shut down. What would I do?
  • Ram Lac-amen Jun 17, 2009
    tnx bro about the idea. I installed some drivers lately so I system restored ,,the blue screen doesn't apper anymore....
  • 555 Answers
Hello my friend, regarding your problem do you have installed program or driver software lately before this blue screen appear? i guess the problem here is more on the memory dumping of your computer. either the latest installed software is not functioning will or  u have a memory device problem either to much heat or cause by some circuit problem that made the memory device problematic. the worst case here is to replace memory but for now try to check first if the memory is running well and stay in its standard cooling temperature. Or you can reprogram your computer.
Posted on Jun 16, 2009
  • Jonas Awayan
    Jonas Awayan Jun 17, 2009
    Your welcome my friend, if you need more assistance just contact me.
    Thanks
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Blue screen on start up and no response
go in bios and disable the on boot password and if tha blue screen appear again write down the error that is writen on that page and search on the net for it.
Nov 28, 2009 | HP Elitebook 8530w Mobile Notebook
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
A blue screen appears and computer shuts down
At what point in the bootup process is this happening? Can you provide more details on what the BSOD (blue screen of death) reads?
Try rebooting, and hold down the F8 key while it is rebooting. You should now have the option of starting in Safe Mode with Networking. If you don't get a BSOD, then there was a file, program, driver, etc., that caused the issue. You can also boot in Safe Mode with Log(?, I'm not 100% sure of the name, but you should be able to spot it), and what that will do is show you what is being loaded and at what point the failure occurs. That shoud narrow down the cause of your problem. Once you have removed the problematic file, program, driver, etc., you can reboot, press F8 and boot in Normal Mode.
Apr 16, 2009 | Compaq Presario 700 470024-192 Notebook
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Acer Aspire 5920 will not start up either in safe mode or normal
IF YOU DON'T NEED ANYTHING ON YOUR PC YOU CAN FORMAT IT WITH YOUR WINDOWS OR RECOVERY CD
SOUNDS LIKE YOU MAY HAVE ALREADY LOST FILES
LET ME KNOW HOW THIS WORKS
Dec 27, 2008 | Acer Aspire 5920-6727 Notebook
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Having troubles
h sir
i think that u have not update the anti virues so, it may be affected..
first re- install and update the anti- virues. it will fix the problem.thank's sir
Sep 03, 2008 | Sony VAIO VGN-N250N/B Notebook
Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
Aug 01, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
