Question about Sanyo PM-8200
Won't turn on
My phone just stopped working yesterday.  it started with the display on the outside not illuminating.  i tried to turn it off to reset it, but it wouldn't turn off.  so i took the battery off and now it won't turn back on.  what's up with this phone??
  • sethmeister Jan 23, 2008
    My phone said that the battery was low and powered down so I tried to charge it and it would't charge then I tried to turn it back on and it won't turn on but the keys will blink until I take the battery out.
Sounds like you both need to contact your carrier for the repair office phone number. Sometimes the carriers can reset the phone for a fix, sometimes the phone needs more detail attention that a repair office could help with,.
Posted on Jul 16, 2008
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Dec 27, 2017 | Maytag Washing Machines
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My turning signals don't blink on the outside and stays illuminated on the inside and also the front outside. My turning signal fuse is also well. I've noticed that my back up lights stopped working. Would...
Usually if you turn on your turn signal and it stays lit solid inside, it's telling you the bulb is bad in your turn signal outside. I would check your bulbs first. Same for the backup lights.
Jan 14, 2015 | Cars & Trucks
2006 Honda Accord Vp Stereo System went out and i have checked every fuse and nothing is working! It started out with the DISPLAY ILLUMINATOR now the whole STEREO went completely Is there any
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
Apr 27, 2012 | Cars & Trucks
I have a panisonic vcr and the remote won't work,. If I replace the remote will it be ok. it was working yesterday
Take the remote and point it at the camera lense of you camera phone or digital camera. If you can see the illumination of the led in the camera lcd display then the remote is ok. If not then the remote is bad or the batteries are dead.
Sep 08, 2011 | Televison & Video
Switched from manual to Honeywell rth230b. It was working fine until yesterday. We had it since last June. AC worked all last summer and Heating during winter. The AC was working this year too until...
I will assume this is a central air conditioning system. From what you tell us about the symptoms a few things come to mind for you to check.
1. Change your thermostat and see if that cures your problem.
*The following steps requires the use of a multimeter and work around electricity, use due caution or call a professional.*
2. Check the contactor inside the outside unit while you have the thermostat calling for cool and see if it is pulled in or if it is stuck. If you are not comfortable around high amp electricity then please call a professional in your area to make these checks.
3. Check to see if the thermostat wires going to the outside unit are sending 24 to 28 volts to the unit. This will tell you if the problem is outside or inside the home. If there is no voltage there then check at your furnace to see if the t-stat is sending the power on the Y connection.
There is much more to check but this should get you going in the right direction and will locate the problem in most cases.
Hope this helps.
Jun 14, 2011 | Heating & Cooling
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
How to be turn on Display light Nokia E61i Mobile????
Go into settings and open phone settings and then display settings
Apr 24, 2011 | Nokia E61i Cellular Phone
Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Jul 29, 2009 | LG Dare VX9700 Cell Phone
Cell Phones Logo
65 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
