Question about HP PSC 1410 All-In-One InkJet Printer
Psc is not installed
Not installed but an error is occured
    President:
  • HP Master
  • 1,996 Answers
See links here and here to help with your problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
I'm getting an error message of 0xb900009f
Lots of issues can be responsible for your error message:-
Access deniedThis error occurs if the user has insufficient privileges to a file, or if it has been locked by some program or user.The device is not readyThis error most often occurs when there is no floppy disk (or a bad disk) in the disk drive and the system tries to perform tasks involving this disk.File not foundThe file concerned may have been damaged, moved, deleted, or a bug may have caused the error. Alternatively, the file simply might not exist, or the user has mistyped its name.Low Disk SpaceThis error occurs when the hard drive is (nearly) full. To fix this, the user should close some programs (to free swap file usage) and delete some files (normally temporary files, or other files after they have been backed up), or get a bigger hard drive.Out of memoryThis error occurs when the system has run out of memory or tries to load a file too large to store in RAM. The fix is to close some programs, or install more memory.[program name] has encountered a problem and needs to close.
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
My computer doesn't recognize that my printer is hooked up every since I unplugged it and moved it.. I don't have the manual and I know that there is a certain order in which things are pluged in.
To avoid errors, install the HP PSC software before you connect the HP PSC to your computer. If an error message appears and you clicked Next or OK, do the following:
1 Press Esc on your keyboard to exit.
2 Turn off your HP PSC.
3 Disconnect the HP PSC from your computer (detach the USB cable).
4 Follow the software installation steps outlined in the Setup Poster that came with your HP PSC.
If you receive a message that you have a previously installed version, you will not be able to finish installing the HP PSC software. You will have to uninstall the previously installed version in order to install the HP PSC software.
If your computer is unable to communicate with your HP PSC
If communication cannot be established between your computer and HP PSC (for example, the HP PSC status icon has the yellow error triangle), try the same tasks outlined under If Microsoft’s New Hardware Found message does not appear on page 57 of the manual.
Here is a link to the manual for your printer...
http://h10032.www1.hp.com/ctg/Manual/bpu05065.pdf
Jan 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1410 All-in-One - While installing from CD an error occurs. Cannot access file. Please solve this problem. Can I have a free download of the driver.
It will be better if you try installing the drivers available default in the computer.
go to printers and faxes --->choose add a local printer--->make sure you check the right port,for HP PSc it should either be DOT4 and most likely the USB port--->when you get the manufacturers list---->choose HP and in the right pane look for PSC 1410 AIO ,if no matching drivers are found,choose Hp Deskjet 990c ,this works as the default printing drivers and you shouldn't face any issues as far as printing from the computer is concerned
for further clarifications you may reply here.
Jun 09, 2009 | HP PSC 1410 All-In-One InkJet Printer
Cant install a printer
HP PSC 1410 All-In-One InkJet Printer installation
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
Found New Hardware error message
that can come from having two of them on the printer profile..open that to check if the computer is looking for two printers.
Mar 10, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Aug 06, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
