Question about Intel DG31PR Motherboard
Sound from tv only wen speakers r connected to pctv
In this case no sound from computer..
Makes quick gurr gurr sound in tower. what is happening. computer is slow too
This sounds like a bad fan, could be a case fan, cpu or power supply so need to identify where its coming from by taking the side of the case off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Mar 22, 2014 | Gateway GT5477E Desktop Computer - 1009589...
Card installation
1) Turn the computer on. When Windows has loaded all the way, put the Installation (CD) disk in your optical drive. Load the software.
No disk? Go to the Sound Card manufacturers website, and download the software. Now INSTALL it.
If asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off.
FOLLOWING Anti-Static Precautions, and computer unplugged from power, open the computer case, and physically install the Sound Card.
Close the computer case, do not forget to hook up the audio wires to your sound card.
Plug computer into power, WAIT 1 minute, turn the computer on.
2) Doesn't have a sound adapter card, and is just Integrated Audio?
Download AND install the audio drivers from Asus for that motherboard, AND Operating System you are using.
(Win XP and Win 7, are two examples of an O/S)
Need further guidance than this?
Post the Sound Card manufacturer and Model Number.
Also post the model number of the Asus motherboard.
Post in a Comment.
Regards,
joecoolvette
Sep 03, 2012 | ASUS Computers & Internet
Dell working but continuos beep sound
beeping sounds are warning to users that computer parts need servicing, it may be memory cards , hard drive , fans or power supply, call tech support if system is still under warranty.
Jun 05, 2012 | Dell Case Fan Assembly for PowerEdge 2800
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
Speakes dnt work on the rh side wen putin cd on wen putin aux in dnt work on the lh side wen radio on they all work
check the connection to the speakers at the speaker otherwise you may need a new sound card in the computer itself...
Feb 13, 2011 | Audio Players & Recorders
I did buy a PC TO TV KW 1600 , when I connect the S-Video cable to TV I don't have any audio from tv. Can you help me
The converter is for video only. To get the audio as well, you'll need to connect a cable from the computer's audio output jack to the TV's audio input. The computer end will need to be a 1/8-inch stereo plug (like the one you'll find on iPod headphones), with RCA plugs for the TV. Here is one from Radio Shack, so you'll know what to look for. Connect the audio to the same AV input as the S-video cable and you'll have both picture and sound.
Nov 28, 2010 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
No sound
If you have not emptied the re-cycle bin, the songs can be restored.
Jun 11, 2010 | A-Top XBlade Mid-Tower Case
Cant get no sound on my pc
Please reinstal your sound driver on your computer
Mar 13, 2010 | Packard Bell (ATXMH28AP) Full Tower Case
PCTV TO GO CANNOT CONNECT TO PCTV TO GO
Restart your computer and plugin back again.Make sure also you have better signal or availability service in your place to work with a PCTV.
Dec 18, 2009 | Pinnacle PCTV To Go HD Wireless TV Input
Intel DG31PR Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
