Question about SanDisk Sansa e260 MP3 Player
Recovery mode formatting failed
I downloaded the program that's supposed to format your mp3 player after you set it to recovery mode. It says "ERROR! Application failed to read the version details!"
Is there anything I can do short of sending it back to them?
  • 1 more comment
  • Anonymous Nov 03, 2007
    format data base
  • Dajam Nov 05, 2007
    Everyrthing I tried didn't work. Please help.
  • jeldi Nov 06, 2007
    my video files are not displaying. just it is displaying empty. same for pictures also. but songs and radio was working fine.
  • 626 Answers
"Application failed..."
Means that this version is not for your player.
You have the Rhapsody version, which is not compatible with this software.
If you call SanDisk Support, they can email you what you need.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Posted on Oct 31, 2007
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
SANSA c240 fails booting
i want softwere of sansa c240
Jul 08, 2008 | SanDisk Sansa c240 MP3 Player
(your device will say the word Rhapsody on the back)
1. Double click on My Computer so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see the orange colour.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called "16MB FORMAT". Once you see that icon you may release the Record button.
5. Double click the RHAPSODY- file you downloaded earlier and open it. You will need WinZIP or WINRAR to "unpack" it. Inside you will see a file named PP5022.mi4 drag this file onto the 16MB Format in My Computer mentioned before.
6. Double Click on the Sansa.rar and open it. Drag the Sansa.fmt file into the 16MB Format as well (this forces the device format and erase all data)
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e260 MP3 Player
Error with formatting
Its not a firmware update you are running, it is a recovery tool. The "application failed to read version details" error is because it is not meant for your device. You have a Rhapsody version and the firmware is different. You will need to call SanDisk for them to email support documents. SanDisk Technical Support 1-866-726-3475 If you are truly trying to format the device, change the mode on the device Settings>Mode or USB Mode, then try formatting again. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
Downloded recovery from sandisk website now get error msg
That software only works with the non-Rhapsody versions, hence the error message. You can call technical support and they can walk you thru the fix. Its too much to type. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
Load main failed switch to recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e260 MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
Songs won't Sync
To enter recovery mode:
1. Make sure the hold button is on, (look for orange) and hold down the record button and plug into the computer.
2. A 16MB Format drive should appear in My Computer under Devices with Removable Storage, you are now in recovery mode.
Now download the following File:
Run the file after downloading and follow the on screen instructions, making sure to connect your player in recovery mode.
Make sure you select the option to Format when giving the option.
after running the program, remove hold from on top of the player and disconnect the player when completed and completion should be set for the player.
After running this, try downloading songs again. Remember to make sure you authorize your player and ensure that the songs being transferred are available for transfer.
Mar 27, 2007 | SanDisk Sansa e200 MP3 Player
Frozen MP3 Player
There's a reset hole by the side of the player. Try reseting it. It can freeze sometimes, and fix itself after a while. no apparent reason. reset, run the battery down and recharge. Hope it helps. this is from the creative site: The recovery mode consists of these four operations. * Clean Up: It is the least destructive operation. It scans a player's hard disk and removes any invalid links from the music library. It does not affect music files themselves. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware. It is recommended that you clean up regularly if you frequently transfer files between a PC and your player. * Format All: It is the same as a Windows format performed in a PC, and consequently all contents will be lost after a format. * Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player. Note : It requires the player be connected to a PC that meets the player's minimum system requirement. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install. * Reboot: Reboots the player. You can reboot the player after performing a clean-up or format, or reboot it without performing neither of them. It is recommended that you try these operations in the following sequence: reboot the player; clean up and reboot; format and reboot; and finally, reload the player's firmware. If your player seems to stuck in the recovery (rescue) mode, you can try the "reboot" operation first, and format the player if necessary. If it fails to reboot, you will need to connect the player to a PC, and reinstall its firmware. For a detailed instructions on how to install a player's firmware, please refer to Updating the firmware on a Creative MP3 player, or refer to the Web Release note of the firmware download. Unlike other hard disk based players, Zen Neeon does not have a rescue mode. Though there is a Player Recovery Mode , it is for use when updating its firmware only. 1. Detach your player from your PC , and ensure that it is turned off. 2. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications. 3. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe. 4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen. 5. Hold down the Play/Pause button while connecting the player to a PC's USB port. 6. When the Creative logo appears on its screen, release the Play/Pause button. The player is now in Player Recovery Mode.
May 19, 2006 | Creative Labs Zen Neeon MP3 Player
SanDisk Sansa e260 MP3 Player Logo
187 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
