Question about Western Digital Hard Drive
My second not show in my computer
In my computer two hard disk drive but i can see only 1 hard disk drive i check this pc to expert engineer but he replace the wire of hard disk and after that my hard showing up in my computer but again this problem occure please help me in my intel dual core processeor 1.60 ghz and 2gb ram befor 5 months before my motherboard faild and i change the motherboard from lenovo so when changed the motherboard i think that i should add new graphics card of nvidia. after that after 30-45 minutes my computer show a blue screen for a second but after that computer restart what is problem in my computer sooo please help me????????????????????????????????????
  • 700 Answers
It is a desktop unit I supposed? Hello, first of all do you change your motherboard with the same type? If not, and you used the same hard drive with the software installed intact. There will be software configuration conflict, since it is a different mobo, different chipset and different driver to run it. Including the video card. My suggestion will be a fresh installation of the software. It lessen software-driver conflict and is direct configuration to your new set up. This can also a hardware ID conflict.
Posted on Jun 16, 2009
I just bought a Dell Back-up plus 1 TB hard disk . when i plug in the USB cable it does not show up on My computer but it shows on "Device manager" and "computer management" .. so i cannot use it as a...
The only thing that I can think of is that you need to go into computer management and click on the "disk management" sub-heading under storage. From there all of the hard drives in the computer should show up. Find the new hard drive in the list and right click on the part where is say Disk 1 or Disk 2 or which ever disk is the correct one (it should be around 930gb or so). Then select initialize disk, and follow the wizard through the choices to setup the disk as a basic hard drive. After the disk is initialized you need to format it and then you should be access the drive in my computer.
Austin
www.we-supply.com
Aug 08, 2013 | Computers & Internet
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
My WD 1TB hard disk drive shows me loaded with 300GB capacity of folders but when they are not seen on my pc
1) Open any folder on your your computer and go to: Tools > Folder options > View tab > check "Show hidden files and folders" and uncheck "Hide protected operating system files". 2) Look at your hard disk again, if you still can't see any files on it, there must be an error of your disk. To solve it, go to: My Computer (or Win+E keyboard shortcut) > Right click on the drive representing the 1TB hard disk > Properties > Tools > Check Now... > Check both boxes to fix errors.
Mar 07, 2011 | Western Digital My Book Essential Edition...
When i plug in my pc, it is not detected therefore I am unable to open the file
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Software Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Jan 01, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My Hard Disk is not being detected by my computer and i think there is a problem inside the hard disk as i cannot feel the normal spin inside the hard disk
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
Good luck
Jan 01, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
My external hard disk does not work.I dropped it.When i connect it to the computer, it makes a sound.It does not work.What to do?
Good luck
Jan 01, 2011 | Imation Apollo (27223) 250 GB USB Hard...
My external hardisk is showing in device manager but it is not showing in disk manager
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your bios settings
Feb 03, 2010 | Toshiba MK6034GAX (HDD2D17) 60 GB Hard...
Second hard disk drive not detected???
What was the error on the blue screen? need the error and the error number. I would check the cable connecting the hard drive to the motherboard and replace it. also try plugging it into a different plug if its sata
Jun 16, 2009 | Computers & Internet
Help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Mar 05, 2008 | Computers & Internet
Data recovery from External Usb Hard Disk
Fixya has received a growing number of USB connected Hard disk failures in recent months. It would appear they are a poor backup device, at least over the long term.
A couple of possibilities: First, disassemble the drive enclosure, and check the connections to the drive itself. I've seen one instance where an internal connection was just loose enough to cause a problem.
2. You could try removing the hard disk from the enclosure, and installing it as a second drive in a standard desktop PC. Interfaces must of course match- assuming it is an IDE interface, install it in a desktop with that drive connect system.
Master/slave jumpers must be also set correctly.
After this, using the drive management tool in Computer Management, try mounting the drive.
Beyond this, data recovery could be difficult at best. There are data recovery services available, but such is fairly pricey. You will have to decide just how valuable your missing data is.
Nov 26, 2007 | Computers & Internet
Western Digital Hard Drive Logo
128 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
