Question about Canon NP 6545 Copier
I'm still new with Canon NP6545, what should i do when message appear " The cleaning web need to be replace" ? Which part is CLEANING WEB ?
    President:
  • Canon Master
  • 1,447 Answers
Your fuser unit heat roller upper cloth roller it is called web roller open it and rotation first posotion.Now it is end position
Posted on Jun 16, 2009
How do I replace Canon NP6230 cleaning web
Easy.when you pull out the transport,open the fixing unit cover(one screw),than,on the left and right you hawe two more screws.Open it and take out web,and replace it with new one
Oct 09, 2014 | Canon NP 6230 Copier
E005 error
The cleaning Web for the fuser has exceeded its acceptable life counter. The web needs replaced and the counter reset in service mode.
Cleaning Roller Part Number- FA3-8908-000
After replacement, be sure to reset the cleaning web counter in service mode under.
COPIER>COUNTER>MISC>FIX-WEB
To access service mode press the asterisk ( * ) the number 2 and 8 at the same time, then the asterisk ( * ) again.
Oct 09, 2013 | Canon imageRUNNER 400S Copier
E005 canon np6545
A E005 means that the fuser cleaning web needs to be replaced. Also, after you replace the web, you need to reset the web counter in service mode. Also, it is a good thing to check the waste toner bottle at the same time... Good Luck
Sep 30, 2011 | Canon NP 6545 Copier
Canon NP6545 Error 0005, please help me... Tq B4
this is error for fixing web cleaning belt.call service for exchange of web.
BUT THIS IS OLD MODEL AND MAYBE THER ISN'T SPARE PARTS AVAILBLE ANYMORE.
THIS ERROR CAN BE RESETED IN SERVICE MODE, BUT IT IS COMPLICATED FOR YOU.(BECAUSE OF SERVICE TOOLS AND SKILLS )
Aug 20, 2011 | Canon NP 6545 Copier
I have canon IR 400 M/c. Now It is showing Error E005 As per instruction on panel. M/c OFF and On. But no use Its shows E005 error
that is the lifetime of WEB CLEANENG is over. which position is in heater unit
this is a picture of heater unit.
you must replace a new of web cleaning.
this is a picture of web cleaning.
or sensor of web cleaning doesn't work.
if it,s the problem you just clean up with alcohol spray.
please try it.
May 28, 2011 | Canon imageRUNNER 400S Copier
I have a copy machine the model is canon np 6551 and on the screen there is a message E005 switch the power on and off again what should I do?
it is code for cleaning web. the fuser cleaning web may have tqken up completely if so, replace it. else check sensors which detect taken up cleaning web.
Jan 28, 2011 | Canon NP 6551 Black and White Copier
I have an error message of E000005-0010. What does this mean. Thanks
The error code E00005 means that the fuser cleaning web needs to be replaced and the web counter needs to be rest.
Sep 24, 2010 | Canon imageRUNNER 8500 Copier
How to reset eoo5
press*28* to enter service mode select copier>counter>misc/fix web then press cancel button this will clear cleaning web count you do need to replace the web as it has run out hence the error code good luck
Nov 27, 2009 | Canon imageRUNNER 400S Copier
Cleaning web low message
Hello Pene."pinetree1" is absolutely right. But may I elaborate in an effort to help you avoid your copier going down. The "cleaning web " is a consumable item that in essence is used up kinda like a roll of toilet paper.As it is used there reaches a point where the copier "knows" that it is close to the end and warns the customer before the roll has run out, to give them enough warning time to make arrangements for the roll/web to be replaced before the copier sees a second indication that the web is running out. The second prompt will result in an error code and the machine will shut down.Typically the copier continues to run appoximately 2000 copies after the "web low" message is displayed. This varies depending on the model and the customers usage. I am sorry I cant "fixya" but at least you have better understanding of what is occurring. I have no way of knowing how mechanically inclined you are, as I might try to walk you thru the replacement procedure.And if you have access to a new cleaning web and feel inclined to have me help you I will gladly do so. I just wanted to give you a few more details, and perhaps keep the "copier dude " from raping you by telling you that you need all kinds of stuff. For a trained tech it is quite simple. My e mail is jdh6211@comcast.net if you need further help. If you would be so kind as to give me a decent rating when you provide feedback to "FixYA" I would be grateful. ..................SPINAL
Jan 23, 2008 | Canon imageRUNNER 5000 Copier
Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
May 07, 2007 | Canon ImageRUNNER 330s Copier
Canon NP 6545 Copier Logo
163 people viewed this question
old marine
old marine
