Question about Nokia 1600 Cellular Phone
Nokia 1600 ,insert sim and not charging solution
1600 display coonector
Posted on Dec 21, 2007
  • 4,102 Answers
Sounds like the unti has been dropped or got damp or wet their is nothing you can do yourself because taking it apart you need to know the order to undo it and put it back together take it to phone shop and they will send it off and have the board cleaned hopefully this should solve your problem if it is anything worse they will tell you before the charge you hope this is some help
Posted on Oct 31, 2007
When i insert my sim it says insert sim..this is my problem in nokia 1600
Try unlocking your phone before you insert a new sim. Cell phone unlocker will help you unlock it
Dec 19, 2011 | Nokia 1600 2610 6270 1110
If your Nokia 1600 says invalid Sim means it locked to Network,You need to Unlock it,You can get the Unlock code from unlokcing4free and Unlock it from Network Lock...
Jul 28, 2011 | Nokia 1600 Cellular Phone
Nokia insert sim track mising problam
try your sim in a different phone and make sure its not just a bad sim. if it is a bad sim most companys will give you a new one free of charge. if it works in another phone you'll want to do a master reset to see if its a software problem or a problem with the actual hardware (the metal connections that interact with the sim). to do the master reset per,http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf select menu, settings restore factory settings, then restore all. if it asks you for a code it will be 12345 or 1234 unless you set another pin in which case it will be your pin. i hope this helps
Dec 24, 2010 | Nokia 1600 Cellular Phone
Can i insert reliance gsm sim in nokia1600 phone
Yes, You can insert reliance GSM Sim in your Nokia 1600
Thank You
Aug 17, 2010 | Nokia 1600 Cellular Phone
My nokia 1600 phones problems Insert SIM
1st, try to clean pin of simcard, you cau use eraser, or maybe simcard ic problem. If you set drop it before, by using soldering iron, Solder with a lot at the end of the soldering iron tip, place on the surface of the ic, the process must be done carefully. never press the soldering tip, leave a lot of Solder is the press. but remember, you need to apply some sim Solder flux in the IC. If the problem is still not finished, then you need to change sim ic new.
Jul 27, 2010 | Nokia 1600 Cellular Phone
Insert sim
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using IPA solution. This problem is caused by Firmware problem and Hardware problem as well. Good luck.
May 15, 2010 | Nokia 1600 Cellular Phone
Insert sim problem in nokia 1600
ok did the sim card go with this phone origanally?
if not you will need to flash the card so that it works with this phone.
Nov 14, 2009 | Nokia 1600 Cellular Phone
Security code Nokia 1600
Have forgotten my Security code for my Nokia 1600
IMEI 358370001451587
I use these two service providers, and created Security Code with Mascom Sim card inserted into the phone
Sep 16, 2008 | Nokia 1600 Cellular Phone
Break my security code
The Code is - 5063657101
Jul 09, 2008 | Nokia 1600 Cellular Phone
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. try to change a new battery' or maybe the sim card driver is unsoldered' or need to replace. here is the pics. skilled technician can do. a4f7f33.jpg
Oct 04, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
211 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
