Crt monitor has decreased width at mid portion. Top & bottom width ok.
  • 35 Answers
Your monitor has alot of electrolytic capacitors inside it.
they typically have a life expextancy of 3 to 5 years ( depending on the temperature in which they operate )
your montor has bad capacitors
if you know about the HighVoltage that is stored in the CRTube itself acting like a capacitor...... and know how to safley discharge the tube and keep it shorted with a clip lead so it doesn't re-establish a charge... which it will..... Great !
If not
do not attempt repair
OK you may not have to disconnect the tubes HV wire to replace the caps...
but you get the picture,
you can get killed or hurt if you dont know what you are doing...
in what is required to fix your monitor.
replace the bad electrolytic caps
they have developed high ESR
Equivalant..SeriesResistance and you can buy a meter to find these bad caps in your monitor.
cap esr meter
good luck
Posted on Jun 16, 2009
  • artiedc
    artiedc Jun 16, 2009
    your monitor has alot of electrolytic capacitors inside it.
    If not
    cap esr meter
    good luck
LG 700e crt monitor is showing all in rainbows!!!!
Remove any speakers or magnets that you might have near the monitor as they can cause visual distortion on your monitor screen.
Mar 05, 2014 | LG Studioworks 700S 17" CRT Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Black line over entire width of ctx monitor screen 1mm depth in mid screen.
You need a new screen surface...you can order one from any reputable dealer....just take your monitor apart and unattach all of the components and replace the screen area with the appropriate part. You are not specifying whether or not it's an LCD or a CRT...if it's a CRT just go buy a new one :) if it's an LCD you can replace the screen for 100 dollars or so.
Dec 15, 2009 | CTX Computers & Internet
Task bar shrinking in width working after sometime. task bar width slowly decreases while working. task bar items appear distorted
There are several high voltage capacitors in this circuit. One or more is beginning to fail. These caps need to be tested with an ESR meter to determine their status. Take the monitor to a pro or visit my site WWW.micromendllc.com
Oct 12, 2009 | Compaq 7500 17" CRT Monitor
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
Monitor display problem
there is a problem in the vertical , change the ic please
Dec 17, 2007 | Philips SoHo 105E 15" CRT Monitor
My AOC 17" CRT monitor displays large veiw on DOS & some PC DOS games where the top portion is displayed at the bottom of the screen.
sounds like you need to run a screen config wizard. If you have a true Nvidia driver you can do this. Otherwise, re-download the driver from the main website http://www.nvidia.com/page/home.html
and it'll work for you
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 01, 2007 | AOC CT700G 17" CRT Monitor
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
