Help Needed Plz
I am using dv 2401tu laptop i uninstaled vista and instaled windows xp and instaled all drives following sandeeps instructions problem is thit i am not geting sound from external speaker but i am geting it from laptop speakers only.Actually i am not able to hear sound when i am connecting external spakers and also i am using win Xp and the drivers is not supporting the headphone jack port...Plz is there a solution
  • 4,924 Answers
Double clic the volume icon from the task bar ( tray ) and when the device volumes pop up ...go to propieties and choose from there the proper plugs and slots ...verify that the volumes to be up and not muted...and try again ...
from the sound manager you have to choose to prompt you on plug in ...and then you will have the proper plugs for what ever you use...
this last issue I mentionated is a check case that you have to click in order to prompt you for choise each time you plug in or out a audio device..
Posted on Jun 16, 2009
Plz send me step by step information for removing win vist to install win xp. on compaq laptops
For ding this you need windows xp cd
put it in your CD ROM
then press F10 to get into bios and under advanced boot priority change your first option to CD and restart ,it will ask to boot from CD,press enter
You will setup process of windows xp,it will ask you where you want to install windows xp,choose drive where windows vista is installed (c:) ,then first choose the option of format this drive using NTFS,it will format your windows vista and will start installing windows xp and in an hour's time it will be done
Aug 02, 2010 | HP Compaq Presario V2000 Notebook
To install xp over preinstall vista in Toshiba satellit A200, some soultaion is aviable 1. to disable sata but how to disable sata in toshiba no option is aviable in in toshiba Bios. plz help me
There are case where BIOS stting doesn't contain any point of configuration for SATA.,
Step 1 : Download SATA driver
Here is the link :
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/12474/eng/iata621_enu.exe&agr=N&ProductID=2101&DwnldId=12474&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2 : Download a software called "nlite"
Here is the link :
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Now you need to include SATA driver with Windows XP cd so that windows XP recognize your HARD DRIVE.it can't be include diectly so
Installed the nlite software and follow the instruction by going to the link below.
http://www.nliteos.com/guide/part1.html
Note : Microsoft dotnet framework 2.0 or later is needed to install nlite in Windows XP,but if you are making a bootable Windows XP cd with sata driver pre-install then,you don't need it.
This will 100% recognize your SATA HARD DRIVE.
Hope it will solve your problem.
Jan 02, 2010 | Toshiba Satellite A200-19501F Notebook
Drivers for hp dv 2401tu for xp
download the drivers here http://tinyurl.com/ydgojc7 you just need to select the operating system first. hope it helps.
Dec 01, 2009 | HP Computers & Internet
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
Help needed
thats not a problem with your laptop, it sounds like a problem with your speakers, try using headphones and see if u can hear anything
Jun 15, 2009 | HP Computers & Internet
Original xp
Hi Vostro owner.Dont worry,this can be sorted.Sound issue is not because u installed windows from a Non-dell cd.But i would ask to call up dell because they will provide u the XP disc that should have come with the system or even it is lost from you.Also then we can download the driver from support site : www.support.dell.com and install it.It is just a mere coincidence now.But the reason i'm asking to get cd from Dell is so that u can avoid any future problems with installing XP from a non-dell cd
Mar 18, 2009 | Dell Vostro A860 Notebook
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
SOUND & WEB CAMERA DRIVER FOR PAVILION DV 2401TU ON XP
plz visit the manufacture website and download it for free
Jun 30, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
