Question about Sanyo 24KS62R Cool Mini Split Air Conditioner
Condensor fan motor spinning slowly, sometimes in wrong direction? then it stops and goes in right direction but slowly?
  • 23 Answers
It has to be a bad capacitor for the motor. the capacitor is a round or oval metal cylinder with 2 connections on it. it should be 5mf, 7.5mf, or 10mf. the compressor will also have a capacitor sometimes they share a capacitor called a dual run capacitor. the markings on this cap are. herm = compressor, fan = condenser fan motor, and commune = power in. hope this helps.
Posted on Jun 16, 2009
Why would a torpedo heater fan turn backwards? every time I start my all pro 115,000 heater the fan starts to spin counterclockwise and the heater wont ignite. But when manually spin the fan blade clo
If the fan has a 'run' capacitor, in rare cases, a faulty capacitor will cause a single phase motor to start in reverse. In most cases a faulty capacitor will cause the motor to only hummmm and not start or start slowly running the right direction then overheat and shut off.
See if there is a capacitor, change it first. If that doesn't fix it it sounds like its time for a new motor.
Nov 18, 2014 | Heating & Cooling
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
Condensor fan spinning in reverse
THE MOTOR IS A 3 PHASE MOTOR JUST SWITCH ANY TWO WIRES TO THE MOTOR AND THE MOTOR WILL RUN THE OTHER DIRECTION. BE SURE TO DISCONECT THE POWER TO THE UNIT BEFORE DOING THIS.
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
My HD 4850 fan is not spinning correctly. It will spin normally for a few moments, then make a cranking noise, then start moving extremely slowly, and sometimes it even stops. Now it is not even spinning,...
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
Jan 15, 2011 | HIS H485QT512P RADEON HD 4850 GDDR3 PCI...
My ceiling fan is spinning in the WRONG direction. I know because I have an identical fan spinning in the right direction. How do I get my fan to spin in the right direction? It has been doing this ever...
shut it off, an get up there and see if it has a directional switch, to make it go forward or back wards. also be sure the blades are not upside down on fan motor. the reverse switch should be on the fan motor housing so it can be reversed.
Sep 09, 2010 | Hampton Bay 52 In. White Redington...
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
GDM-12 Refrigerator smells burnt. Any suggesstions?
It could be smelling burnt for a few reasons. The best case scenario would be that the condensor fan is stuck which is causing the compressor to get hot and burn, in this case you would just find the obstruction and remove it. Or the condensor's fan motor could be bad, causing the fan to spin slowly which would also cause the compressor to get hot and burn, in this case you would replace the fan motor. Or the cooler has a restriction in the refrigeration lines causing the compressor to work harder which causes the compressor to get hot and burn. In this case call a refrigeration technicion to clear the lines.
Mar 21, 2009 | True GDM-12 Refrigerator Commercial
Frigidaire side by side model #FRS6R5ESBC
Fan rotation is determined by the motor direction of rotation. Cool air should pass over the compressor then over the condenser. Look from the motor end for the direction of rotation. Drive to driven. Motor is the drive and fan blade is the driven.
Jun 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Sanyo 24KS62R Cool Mini Split Air Conditioner Logo
1,171 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
