Question about Onkyo TX-SR606 Receiver
I am trying to get the volume bar on my tv screen.It works on everything else but not cbl/sat. Receiver is tx-sr606. Thanks
  • 4 Answers
En order to help out here a few questions need to be asked? Is the CBL/SAT connection VIA HDMI? Some HDMI signals will not pass CC and or On-screen display (OSD) via certain video modes. If all is analog video, not a problem, if mixed with component and HDMI and analog, you may experience issues. Let me know your thoughts and the best of luck.
techhome100
Posted on Jun 18, 2009
Hi I have a tx-sr606 receiver. Tv connection is
go to menu and select manual input selection if it is on auto input select
Jun 04, 2010 | Onkyo TX-SR606 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Oct 19, 2009 | Onkyo TX-SR606 Receiver
Intermittent sound with cbl/sat. Sometimes sound
Your receiver is HDMI version 1.1,1.2 or 1.2a and just don't work with anything to be honest with you. It's an HDCP (copyright Issue) and 5v pass thru issue. and the list goes on. If you can, just run HDMI directly to the TV and optical or Digital Coaxial to your receiver for audio and all will be well again. If you need more help, just post a comment and I will gladly help some more
Jun 24, 2009 | Onkyo TX-SR875 Receiver
Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
Mar 25, 2009 | Onkyo TX-SR606 Receiver
Pressing input selector button changes sound only, not vision.
you're right, it definitely shouldn't be doing that! i know that your cables are probably ok, but it sounds like you might have a little software glitch or something going on. i would highly recommend upgrading your cables to HDMI. not only will you have fewer wires to deal with, you will also be upgrading both your sound and your video quality. in addition, the HDMI connections should be totally seperate from the other connections internally. you might luck out and find that only the analog side of things was afflicted. check out Newegg.com. you can get a 6' cable for $10.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2104300697%20117752939%201177412127&bop=And&Order=PRICE
only other option is to send the unit in for service.
Mar 01, 2009 | Onkyo TX-SR606 Receiver
Turns off if sound level is increased
there is a protection circuit kicking in.
First thing to check.....Verifiy that all speaker lines are in correct polarity.
+ and gold or writing/stripe on cable.
Check this all the way around and if the sub is a line in sub,, check that also.
You really should just unplug them all and start one by one.
If you cannot get to the wires or its too hard to access,
hold your hand 1/8 of an inch from the woofers. they should be kicking out, not pulling in.
Could also be a blown woofer somewhere in the system.
Hope that helps!
Charles
Jan 09, 2009 | Onkyo TX-SR606 Receiver
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Nov 16, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
137 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
