Question about Veo Velocity Connect Webcam
I take a snapshot, click e-mail and send: I receives an error messeges: fail to access e-mail address book.  What is wrong?  needs help.
  • Anonymous Apr 25, 2008
    send me drivers.
Webcam hp-turbo driver
Posted on Dec 31, 2007
My inlaws gave us a Veo Velocity web cam. It is
Try downloading the earlier OS software
Right click on the webcam icon on your desktop and click 'Properties'
Click 'Compatability' tab and select to run in the webcam OS you have downloaded
Click 'Apply' 'OK'
By trial and error check the 'Settings' boxes to achieve best results - start with 'Disable visual themes'
Feb 10, 2010 | Veo Velocity Connect Webcam
Cannot get or send mail. error ox8oocccod
Error 0x800CCC0D
Problem: When you try to send or receive email, you get an error message. It
says the error number is 0x800ccc0D.
Solution: This error is basically saying that your computer cannot connect
to the mail server. The most common and obvious cause of this is that you
are not connected to the internet at all. To test whether this is the case,
try opening a news web page like or doing a Google search (just
opening your homepage is not a good enough test, because it may be saved, or
"cached", on your computer's hard drive). If this test fails, then the
problem is not with e-mail specifically, but rather with the internet
connection. For users on dial-up, you need to dial in first, and then you
should be able to check your email. If Windows is indicating that you are
already connected, try disconnecting and then dial in again. If that fails,
try restarting the computer and then connecting again. If that fails, you
may have spyware or your modem may have gone bad.
If, on the other hand, you are able to pull up web pages, yet still get
error 0x800CCC0D, you should check to make sure the mail servers are typed
in correctly. To check this in Outlook Express, open the Tools menu, select
Accounts, click on the Mail tab, click on the Properties button, then click
on the Servers tab. Or, if you use a different email program, follow the
equivalent procedure for that program. The incoming mail server should be unless your email address doesn't end with, in which
case put in whatever your address ends with instead of (for example,
if your address is, enter in ). The
outgoing mail server should be or substitute whatever your
email address ends with for
Make sure to check the mail servers for all your mail accounts if you have
multiple email addresses.
If you still get error 0x800CCC0D, and definitely can pull up web pages
(that is, the rest of the internet is working fine, only email is having a
* Restart your computer. This is simple, so you might as well try.
* Try disabling e-mail scanning in your anti-virus program. To do this
in Norton, double-click on the yellow picture for Norton down at the bottom
of your screen by your clock to open Norton. Then click the Options button
at the top of the window (if a drop-down menu appears, choose anti-virus),
then click the word Email on the menu on the left side. Uncheck both Scan
Incoming and Scan Outgoing. Click OK, then close Norton. Try checking your
messages again.
* Disable your firewall. It could be blocking Outlook Express, or
whatever your email program is, from accessing the internet. McAfee firewall
will usually not turn off even when you tell it to, so you'll have to go
into the firewall settings and delete your e-mail program from the blocked
list, or just uninstall McAfee firewall entirely using the Add/Remove
Programs control panel.
* Make sure you recieve replies when you ping the mail server. If you
cannot, something strange is going on.
* Try checking email using a different mail program such as Thunderbird,
or through webmail on our web site, and see if that works.
Other Cases
You may be able to get mail when you first open Outlook Express, but then
get error 0x800CCC0D from then on. To solve this, go to the Tools Menu >
Options > Connection tab, and uncheck "Hang up after sending and receiving".
Your email works fine, but error 0x800CCC0D keeps constantly popping up over
and over. In Microsoft Outlook, Tools > Options > Mail Setup tab > Send and
Receive, and uncheck "Schedule an automatic send/receive every 5 minutes"
(older versions of Outlook will have a similar option under the Mail
Delivery tab). In Outlook Express, go to Tools > Options, and uncheck "check
for messages every ... minutes".
Aug 30, 2009 | Sony VAIO JS Series Desktop Computer...
Receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from:
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
Jun 23, 2009 | Veo Advanced Connect Webcam
VEO VELOCITY V006 webcam
1st You download Webcam Driver. Veo Velocity Cam Driver After this install the webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Jan 21, 2009 | Veo Velocity Connect Webcam
Veo stingray web cam not working
i need the veo stingrays's v330 drive send to my mail please
thank you...
Oct 13, 2008 | Veo Stingray
Snapshots problem
Do you have the Veo Digital Studio Application? If so, double click on the icon for it:
1. Click the Take A Snapshot button on launch your Veo camera.
2. Focus/ adjust as necessary. Use the Small, Medium, and Large buttons to select the desired resolution, then click Take a Snapshot.
3. Click:
a) Retake Snapshot - To take another snapshot *if you don't like the one you took*.
b) Click Save- To save your picture. Select the destination folder and rename the picture if desired. If left unchanged, the picture will be save in the default directory C:\Program Files\Veo Digital Studio\Gallery\Photographs.
Aug 30, 2008 | Veo Stingray
Free Software, drivers, installers for VEO Velocity
This is where you will find what you are looking for, drivers are there called Veo Velocity Connect bunch of other useful stuff you might be able to use
Aug 23, 2008 | Veo Velocity Connect Webcam
Address Book page does not open, whilst forwarding emails received.
Is this say yahoo mail?, outlook mail?, google mail?
Dec 22, 2007 | Computers & Internet
HI roming1
put your junk mail up and ill send it to you . Drivers i meann ..
Cheers M8
i need a driver for this webcam ( VISTA ) please anyone ?
Dec 08, 2007 | Veo Velocity Connect Webcam
Veo velocity voo2 web cam
Hi I think ya drivers will B at the link below.... Veo-Stingray-V002-Veo-Stingray-V002/ download/page,sh,1612,303,17,.html Ya may have to join, it's free & handy.
Sep 17, 2007 | Veo Velocity Connect Webcam
Veo Velocity Connect Webcam Logo
287 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
