Question about HP LaserJet 2605DTN Color Printer
My hp colorlaserjet printer 2600n, has a black background on the page, and I did every thing that I thought the solution like I Put anew black cartridge, cleaning mode but is does go away so what can I do please?
  • cbaxsane Jun 18, 2009
    thanks for your solution point , let me put my problem of my printer in other way My toner cartridge does spliting on the page becouse i changed the black cartridge and i put a new black cartridge but still the print out has black shadow behind text that makes the page dirty
    so can you do again another solution?
    President:
  • HP Master
  • 1,447 Answers
Your balck cartridge toner is demase or drop toner on this page change it
Posted on Jun 16, 2009
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
I am getting a black/gray shadow of other parts of the page down the right side of each printed page
This is called backgrounding. It is a common issue with this machine when you print past the reccomended out or use inferior remanufactured carts. This is usually either a poorly adjusted doctor blade in the cartridge, or if it is an HP cart, it has a prematurely full waste bin and is transferring waste toner to the page. Either way, replace the cartridge.
Sep 29, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n
Yes, u can just clean the drums , I means the rolls inside the printer, just open the printer door , then remove the cartridge , then u can use tissues with a little of alcohol to clean the rubber rolls inside .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Page is printed but fade
The toner cartridge is faulty. It is possible that when you pulled out the strip that the whole thing didn't come out. Return the cartridge (with a couple of printed sheets to demonstrate printing) and the receipt and you should get a replacement.
Oct 24, 2008 | HP Color LaserJet 2600n Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Dec 05, 2007 | HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
HP LaserJet 2605DTN Color Printer Logo
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
