Question about D-Link DIR-625 (790069292637) Wireless Router
How do you unblock your computer with a D-Link DIR-628 router? My brother blocks me and I'm trying to play some team fortress 2. My connection just dies cause he blocked the router at the worst times. Is there anyway to get around this?
  • 428 Answers
You can do a port forwarding first, remember, to configure router you have to log in as an administrator.
Type in this in your browser's address bar.
http://192.168.0.1
Log in.
These are the ports
Steamclient1: 27000 - 27020
Steamclient2: 27020 - 27050
SteamServ: 27015
Do like this(at your own risk-port forwarding may be vulnerable)
This will allow you to open a single port or a range of ports.
Port Forwarding
Enter a name for the rule or select an application from the drop-down menu. Select an application and click << to populate the fields.
Enter the IP address of the computer on your local network that you want to allow the incoming service to. If your computer is receiving an IP address automatically from the router (DHCP), you computer will be listed in the “Computer Name” drop-down menu. Select your computer and click <<.
Enter the TCP and/or UDP port or ports that you want to open. You can enter a single port or a range of ports. Seperate ports with a common.
Example: 24,1009,3000-4000
Select Allow All (most common) or a created Inbound filter. You may create your own inbound filters in the Advanced > Inbound Filter page.
The schedule of time when the Virtual Server Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
You can also add application rules
Name: Enter a name for the rule. You may select a pre-defined application from the drop-down menu and click <<.
This is the port used to trigger the application. It can be either a single port or a range of ports.
Select the protocol of the trigger port (TCP, UDP, or Both).
This is the port number on the Internet side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges.
Select the protocol of the firewall port (TCP, UDP, or Both).
The schedule of time when the Application Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
Your brother may be filtering your mac address(network card address)
Check from Advanced->MAC address filtering
Turn it off.
You can set a policy also to prevent this.
Here's how
Go to Advanced-> Add policy of your router configuration page.
Do the following
Click the Add Policy button to start the Access Control Wizard.
Click Next to continue with the wizard.
Enter a name for the policy and then click Next to continue.
Select a schedule (I.E. Always) from the drop-down menu and then click Next to continue.
Enter the following information and then click Next to continue.
• Address Type - Select IP address, MAC address, or Other Machines.
• IP Address - Enter the IP address of the computer you want to apply the rule to.
(To find the MAC address
(click Start, then Run, then type cmd in the text box.)
Type in ipconfig/all in the Command Prompt Windows.
The 12-digit Physical Address is the same as MAC address
Select the filtering method and then click Next to continue.
Access Control Wizard (continued)
Enter the rule:
Enable - Check to enable the rule.
Name - Enter a name for your rule.
Dest IP Start - Enter the starting IP address.
Dest IP End - Enter the ending IP address.
Protocol - Select the protocol.
Dest Port Start - Enter the starting port number.
Dest Port End - Enter the ending port number.
To enable web logging, click Enable.
Click Save to save the access control rule.
Go to tools-> syslog to create a new user. you can create an admin account here.
You can download the manual of the router from here.
If this is helpful to you, please rate this :)
Thanks :) Wish You Luck
Posted on Jun 16, 2009
None blocked
I have a D-Link router as well (DIR-628) and the Website Filter does not do anything either. The firmware is faulty and D-Link won't fix it. Unfortunately, the only way to resolve this is to buy a much newer router that does not use the same firmware. Believe me, I understand your frustration.
Alternatively, you may set up a free account at OpenDNS.com where you can block specified domains for all devices that connect to the router. I use this and it works pretty well.
Jul 31, 2012 | D-Link DIR-625 (790069292637) Wireless...
Cant connect to dlink dir 628..
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2011 | D-Link DIR-628 Wireless Router
Cannot connect to dlink dir 628 router, why?
Try RESETTING the router.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
My DIR-628 router is no longer connecting. My comcast modem is fine. Beside the D-Link symbol,, there are 2 lights working. The first from the rright is the circle with a line though the top. The other id...
Resetting router to factory defaults should fix this.
NOTE: Reseting the router to the factory defaults will delete any changes you have made to the router, including any security settings.
You will find reset button at back of router. Near power button. Press and hold the button for 10 secs.
Apr 12, 2011 | D-Link DIR-628 Wireless Router
How do i open the NAT for playing my xbox 360?
Download new firmware. Here's the link. Worked for me. http://www.downloadatoz.com/driver/item_dlink-dir-628-dual-band-router-firmware-1-20b08-beta.html
Jan 03, 2011 | D-Link DIR-628 Wireless Router
I am trying to block my dlink router, because it is unblocked, and i dont remember the password either. How can I fix this?
You wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 18, 2010 | D-Link DIR-628 Wireless Router
My PS3 says that I have 100% signal stength to internet. I don't have the WPA key to get in when I try to connect wirelessly. I am renting a condo and the owner forgot the passphrase. I do have the...
connect to the computer via lan cable, acess the configuration utility by typing the ip adress in the web adress box and then choose the wireless sucurity tab.
Mar 06, 2010 | D-Link DIR-628 Wireless Router
DIR-625 Blocking DWL-G510 connection
1) First you need to check if the router is blocking mac address. Login to the DIR-625 by typing 192.168.0.1 on the address bar of IE.
Use admin for username and leave password blank or type in your password.
Go to Advance Tap, on the left click on Network Filter. Select Turn Off Mac filtering, click on save settings. wait for your to reboot. If that doesn work try option tow below.
2) What you need to do is Upgrade to the latest firmware on your router (Resolves 99% of all problems). Make sure you download the right firmware for there are two version of the DIR-625 ( Rev. A & Rev. C).
You'll also need to make sure you have the latest driver for the adapter since you have a newer computer.
Sep 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
730 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
