Question about Datamax M-4208 Thermal Label Printer
I need driver for datamax m 4206 e mark II - Datamax M-4208 Thermal Label Printer
    Scholar:
    New Friend:
  • 52 Answers
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Posted on Apr 29, 2014
  • 27 Answers
SOURCE: Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Posted on Dec 30, 2008
  • 54 Answers
SOURCE: datamax dmx-m-4206
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
thorne145
  • 3 Answers
SOURCE: We have several Datamax I-4208 printers and a few
Some changes were made on the I Class units and the new printheads do not work correctly in the discontinued 4206 models. You need part number DPO20-2262-01 for your I-4206.
Posted on Jan 19, 2010
  • 617 Answers
SOURCE: Have lost the driver installation cd/floppy disk
link to download drivers, go to drivers pick version to download
http://www.datamaxcorp.com/software/m-class/
Posted on Feb 09, 2010
  • 54 Answers
SOURCE: I have a few Datamax-I-4206 printers and some of
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Posted on Jan 11, 2011
Can not find driver for a meto 4206 thermal printer? where can I get a free one
Feb 07, 2011 | Datamax Office Equipment & Supplies
I want cd for datamax
Yes, you can order another cd for the m-4206 from any authorized reseller. But, do you really need one? All the cd's have old drivers on them, and newer drivers are available online for free download.
Aug 03, 2010 | Datamax M-Class M-4206 Thermal Label...
We have several Datamax I-4208 printers and a few of the older I-4206 models. It would appear the replacement printheads are one in the same for both models be we cannot get either of our spares to work in...
Jan 18, 2010 | Datamax DMX I-4206 Printer
Computer and printer dont communicate we have it on a usb cable dirctly connected from computer to printer we connected our old datamax e-class printer and that one seems to work although the quality is...
its probably a issue of usb 1.0 and 2.0 ..change the usb port and see if the pc its making a sound when you plug it in ..ifthe computer makes a sound like a bel or a ping all you need its a driver for the printer to comunicate with the pc ..and this can be found on the net ..if the printer is Datamax dmx I-4206 this is the driver needed
http://www.mediafire.com/file/mhyjme2ymmz/Datamax.rar
Aug 04, 2009 | Datamax DMX I-4206 Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Aug 25, 2008 | Datamax M-Class Thermal Printer
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Jun 12, 2008 | Datamax DMX I-4206 Printer
Datamax M-4208 Thermal Label Printer Logo
155 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
