Question about Dometic RM2652 Refrigerator
Refrigerator not working on gas
Dometic 3-way caravan refrigerator will not cool on gas. Burner is on but will not respond to thermostat settings
  • neilsam2 Jun 16, 2009
    Thank you Sea Breeze for a prompt reply. Unfortunately the model number was entered incorrectly. The correct model number is RM2553
  • Anonymous Mar 17, 2014
    I have a Dometic RM2510 3 way ( 120v, gas, 12v) it isn't cooling on any setting. This is in a 1993 HiLo.
  • Dometic Master
  • 4,655 Answers
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Posted on Jun 16, 2009
  • John Tripp
    John Tripp Jun 16, 2009
    Below is a link to their customer center. They are good about helping their customer worldwide. Thanks for the vote. I did search for that model in the Caravan 3 way style. They have hundreds of versions. Nothing falls exactly on your model number. You may need to surf their site awhile for your model and the control components. But a talk on the phone with them to get the correct direction for your model is better than the cost of driving to a dealer and getting repairs. YouTube has service movies covering Dometic. Sea Breeze http://www.dometic.com/enie/Internationa...
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dec 05, 2013 | Dometic NDR 1062 Refrigerator
Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 17, 2008 | Dometic RM2652 Refrigerator
No cooling on 12v or gas
Hello,Depending on the age of the unit, it could have a compressor going bad on it, as the compressor gets hot the valves may not be seating correctly or may be burning out.
You may have also lost some refrigerant, but I am going to lean more to a bad compressor.
Thanks
May 30, 2010 | Dometic RM2620 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Dometic RM 2800 Works great on AC but not on LP
Most likely cause is a blocked gas jet in the main burner its rare for the thermostat to be faulty but you cant dismiss it
Jul 27, 2009 | Dometic RM2652 Refrigerator
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
May 26, 2008 | Dometic Refrigerators
Dometic RM2652 Refrigerator Logo
909 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
