Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon ip5300 b200 error message unplugged and replugged lights still flashing between green and orange pulled all printer cartridges no resolve
    Scholar:
  • 37 Answers
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
  • ThriceAF Nov 04, 2010
    Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Why the cartridge does not move when the printer is on. and when i set to print error no. B200 appear?
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#b200
B200 Error- This could also be displayed as P10 or the orange and green light blinking 10 times Description:
B200 is a service error that can occur due to a hardware failure with either the printer or the print head.
Resolution:
In most instances, a B200 error will require a repair at a Canon authorised repair centre, however prior to sending your printer for repair please follow the steps below to try and resolve this error-
  1. Turn off the printer
  2. Disconnect the power cable
  3. Open the printer cover
  4. Check for any orange protective tape or white polystyrene and remove if necessary
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary
  6. Close the cover
  7. Reconnect and turn on
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
If the warranty has expired, then any repairs can only be carried out at cost and charges will apply.
You can find the details of your nearest repair centre using our interactive repair centre locator.
If you own a PIXMA PRO-1 please contact us directly as you may be eligible for an on-site repair.
Jan 14, 2016 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I am having error code B200
VH monitor error
maindoard or printhead failure
only replace can fix this problem
Dec 07, 2015 | Canon PIXMA Office Equipment & Supplies
Flashing green orange lights
The Canon service info is:
B200/P10 - Orange and green light blinking 10 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code is usually given for a foreign object present in the print head carriage path, so check at both ends for a crumpled up wedge of paper. If nothing is found, it is most likely that your print head has an over-heating problem and is dying
Dec 10, 2017 | Canon PIXMA iP4600 Color InkJet Photo...
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Ip 5300 error b200 10 blink orange-green
    Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
    I get a message error that ink cartridge is not well installed
    Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
    Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Canon PIXMA  iP4300 InkJet Photo Printer Logo
    1,501 people viewed this question
    old marine
    old marine
