Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Intermittent 3 inch green vertical line-5 inches from right side
Panasonic Plasma TH-37PX60U - 3 yrs old. Flickering green line appears when background picture is yellow or orange. Problem occurs with satellite feed, DVR or DVD play. Help!
  • marthakaufel Jun 16, 2009
    Approx 5 inches in from the right side... There is a 3 inch wide vertical line that appears running from the top - almost to the bottom. It is mostly green and only appears if the picture background has orange or yellow (or people's faces). It does not appear when there are dark colors or black. It appears intermittently. It appears when we play a DVD or the DVR or on regular Directv feed. It started about a week ago and has gotten worse - greener.. Thanks in advance for any help you might provide. Martha
  • Marco M May 11, 2010
    where is the line? and how thick is it
    New Friend:
  • 58 Answers
It you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Posted on Jun 16, 2009
I just bought a Panasonic TX-PF37X10 Plasma it has a faint line that runs across the screen about 30mm wide from left to right it is more noticable when I have a radio station on as you can see the line against the Blue background
Posted on Jun 23, 2009
Panasonic TH-50PX60U 50 in. HDTV Plasma Television. 4 years old. It has developed a 2 inch by 12 inch vertical black line bordered by intermittent red/grenn pixles in the upper right corner of the screen.
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 02, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
We had a vertical line about 2 inches wide and going from top to bottom on our 42 inch viera that was a light green-barely interfering with picture. Now that area has gone black while the rest of the tv...
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Cheers.
Sep 25, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-50PZ77U 1 1/4" inch vertical line
This problem is usually the ribbon cable connection at the top of the stripe. Reseat the cable first. The other possibility is the panel itself, but that is rare.
Keep us posted.
Dan
Apr 30, 2008 | Televison & Video
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
811 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
