Question about Dishwashers
My LG dishwasher will drain the water fill the water but does not wash. it just has a hum sound
  • 27 Answers
It sounds like the filter is blocked. It may be located the the bottom of the machine under where the dishes are.
Posted on Jun 16, 2009
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
No washing action form the dishwasher
sounds like you have a broken wash pump or if there is a humming sound instead of water splash/spray noise ,something is jammed in pump impellors
Oct 05, 2009 | Dishwashers
My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Humming noise after water fill and will not wash
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Apr 17, 2009 | LG LDF6920ST Stainless Steel 24 in....
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
