Question about Ricoh Aficio 2022 All-In-One Laser Printer
SC998 problem My aficio 2022 has halted in its tracks... The evil SC998 code seems to have taken over the poor machine. Anyone know how to fix this problem i would greatly appreciate. Thanks.
  • 37 Answers
(RAM, DIMM, board)
ends abnormally.
998
D
Application start error
• Download controller firmware
• Replace the controller board
• An option required by the application (RAM, DIMM, board) is not installed
After power on, the application does not start within 60 s. (All applications neither start nor end normally.)
your firmware got messed up propably so you will need to obtain the controller board firmware , or when you print something you select a function on the pc that is not installed on the machine hope this helps you
Posted on Nov 16, 2007
How do i fix the error code sc998?
998 Application start error • Software defective; change the firmware for the application that failed • An option required by the application (RAM, DIMM, board) is not installed
Oct 08, 2015 | Ricoh Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I turn on my ricoh aficio copier 2022 this code sc998 appear
The meaning of the error sc998 is the system software does not start within 60 sec.The cause for that is either the RAM, DIMM (software SD cards), firmware(system software) or the main controller is faulty or not connected properly.
Did you remove chip or SD card from the machine?
Mar 11, 2010 | Ricoh Aficio 2022 Black and White Copier
RICOH AFICIO AP3800C CS 99 CODE HOW CAN I FIX THAT
I am new to this printer myself. but most codes error I see have 3 numbers to it I can only say that the codes I see for this printer with 9 in it are:
SC990 Defective software
SC998 Application start error
Maybe the machine lcd not show all the number on it.
Pineworks.
Jan 05, 2010 | Ricoh Aficio AP3800C Laser Printer
I have a Ricoh Aficio 2022 which displays a service code SC545. Anyone know what this means. Do I need a tecnician to fix? Thanks Steve
This is a fuser overheating problem. I'd try to clean the thermistors and make sure they are touching the hot roller then use SP810 to reset the code. (clear modes, 1,0,7,hold down the clear stop key, enter COPIER SP mode,then go to SP810 and hit execute.
Sep 07, 2009 | Ricoh Aficio 2022 Black and White Copier
Error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Jul 30, 2009 | Office Equipment & Supplies
Error sc548 aficio 1022 ricoh
Poor connection of the fuser, and the code will need to be reset in service mode.
Jul 17, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
1,155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
